When I make changes to the stylesheet I'm using for the TinyMCE, I see no changes. Any ideas why? Caching, maybe? I've tried "calling" the css file directly and it shows the correct contents - but in the RTE there's no changes. I've also tried restarting the application. No luck. This is driving me crazy. Any help would be greatly appreciated.
If you do a "view source" or DOM inspect your output from the RTE do you actually see the classes from your stylesheet being applied? Depending on how you've written your styles there might be a mismatch between how the styles are written and how they're applied.
Otherwise it would be helpful to see what your stylesheet setup looks like and what options you have in the RTE to have some visual context :-)
What I want for example is to pad around images automatically. I've done this in stylesheet which shows up correctly on the frontend. To make images pad correctly in RTE, I've made an img { padding-top: 0.5em; padding-bottom: 0.5em } - but it takes hours - sometime days - for the change to show up for the backoffice user, meaning I cant make small tweaks for the client quickly. I'm thinking this is caused by caching which might update when the application cycles sometimes. Can I force it to cycle or flush the cache?
Do you have a local environment where you can play with some of the cache settings?
I was just about to suggest you tried bumping the client dependency version 😅 but that's not how it works anymore from v9 and forwards - But I think you perhaps should have a look at the different cache settings here and look into if there is a certain combination that works better in your scenario maybe? Because if the new styles get picked up once the application pool recycles it sounds like caching is the issue to me yeah.
RTE styles not showing
Hi Tony
That indeed sounds really frustrating!
Looking forward to hearing from you!
Hi Jan,
Hi Tony
https://docs.umbraco.com/umbraco-cms/reference/configuration/runtimeminificationsettings
Hope this helps a bit!
