  • Neil 40 posts 205 karma points
    Apr 27, 2023 @ 14:04
    Neil
    Getting blocks by guid
    Does anyone know if it's possible to load the model for a block (either the PublishedElementModel or the underlying IPublishedElement) by it's Guid?
    Something like PublishedContentQuery.content(Guid) / ContentService.GetById(Guid) - but for blocks?
  • Søren Kottal 713 posts 4571 karma points MVP 7x c-trib
    Apr 28, 2023 @ 06:16
    Søren Kottal
    Hi Neil
    You need to get the node that has the block first, and then you can filter the block list/grid property to find the desired block.
    Apr 28, 2023 @ 07:51
    Neil
    Yeah, that's what I've ended up doing. I was just hoping there was some build in indexing that I couldn't find documented, to avoid using reflection.
