Using Umbraco.TinyMCE and Umbraco.MediaPicker3 in a custom form
I have a requirement to allow members (with no back office access) to post blog entries in an Umbraco 11 site.
I have created a custom form to do this following this example. It works fine when using a simple Text Area as the main content editor. However, I would like to use the Umbraco.TinyMCE editor in its place.
Similarly, I would like to use the Umbraco.MediaPicker3 editor to allow the member to select an image for the post.
Can you give me an overview of how to incorporate TinyMCE in my form, please? Is it possible to use the Umbraco property editor in the front end, or do I have to add a separate TinyMCE implementation to achieve this?
For the media picker, I think I can probably do what I need by uploading a file, the using the MediaService and ContentService to add it to the page. I'll give that a go.
How do I do that?
using tinymce in the front end is simple enough, however I don't think you will be able to use the Umbraco.MediaPicker3 in the front end
Thanks for the reply, Huw.
You can include the umbraco supplied tinymce implementation by just adding
to your page template, you will then need to add some javascript to bind it to your target, see the tinymce docs.
Thanks Huw. I got TinyMCE working.
