  • Tom Newt 27 posts 180 karma points
    May 09, 2023 @ 17:47
    Tom Newt
    Render Forms in Block Element
    We're working on a migration from v7 to v10. Part of that was migrating our grid content using uSync.Migrations which worked great for rich text and images, but one thing that's not working is our grid form picker. I've tried following the documentation for forms front-end and rendering, but the form is still not displaying. I've created the block element doc type as well as the corresponding partial view, I've included that code below. Inserting a form through the rich text editor works, but how do you display a form in the block list?
    @using Umbraco.Extensions;
    @using Umbraco.Forms.Web;
    @using Umbraco.Forms.Web.Extensions;
    @inherits Umbraco.Cms.Web.Common.Views.UmbracoViewPage<Umbraco.Cms.Core.Models.Blocks.BlockGridItem>
    @Html.RenderUmbracoFormDependencies()
    <script src="https://ajax.aspnetcdn.com/ajax/jQuery/jquery-3.0.0.min.js"></script>
    <script src="https://ajax.aspnetcdn.com/ajax/jquery.validate/1.16.0/jquery.validate.min.js"></script>
    <script src="https://ajax.aspnetcdn.com/ajax/mvc/5.2.3/jquery.validate.unobtrusive.min.js"></script>
    <div>
        @await Component.InvokeAsync("RenderFormScripts", new {formId = @Model.Content.Value("form"), theme = "bootstrap3-horizontal"})
  • Debasish Gracias 27 posts 137 karma points
    Jul 31, 2023 @ 10:45
    Debasish Gracias
    Im getting the same error. Were you able to resolve this Tom?
    Aug 01, 2023 @ 14:51
    Tom Newt
    Debasish I believe I've got this working, at least on our test site. The following hard codes the theme and exclude scripts, but I think it could be modified to pass those values through. Let me know if you get something better figured out. It seems strange to use the rendermacroasync function even though my block element simply uses the forms picker.
    @if(Model.Content.Value("form") != null)
    @await Umbraco.RenderMacroAsync("renderUmbracoForm", new {FormGuid=Model.Content.Value("form"), FormTheme="bootstrap3-horizontal", ExcludeScripts="0"})
    Aug 02, 2023 @ 04:46
    Debasish Gracias
    Tom I was able to get it to work. Here is what I had to do
    • The block element should be at \Views\Partials\blockgrid\Components\form.cshtml
    @inherits Umbraco.Cms.Web.Common.Views.UmbracoViewPage<>
    @(await Component.InvokeAsync("RenderForm",new { formId = Model.Content.PickAform, theme = "default", includeScripts = false }))
    This got the umbraco forms working for me. Let me know how it goes for you.
    Aug 02, 2023 @ 13:50
    Tom Newt
    Yep, that worked for me and feels correct compared to using the macro. For anyone that runs into this here's my final element code.
        var theme = Model.Content.Value("theme") != null ? Model.Content.Value("theme") : "bootstrap3-horizontal";
        bool scripts = Model.Content.Value("includeFormScripts") == "True" ? true : false;
        @(await Component.InvokeAsync("RenderForm",new { formId = Model.Content.Value("form"), theme = theme, includeScripts = scripts }))
