  • Nick Markham 4 posts 74 karma points
    May 12, 2023 @ 14:28
    Nick Markham
    Newbie help please with creating content
    Hi, I create a doc type, give it a template, and then expect to be able to create a content page for the doc tyoe just created but it doesn't appear in the list when i click Home -->elipsis . It does appear under the elipsis of the 'content' branch above, but when i do that i get a 404 Page not found No umbraco document matches the url '/terms2'.
    Ideally, i'm lookng to create a simple page with a RTE on it that doesn't appear in the menu.
  • Abdulaziz 21 posts 235 karma points admin hq c-trib
    May 12, 2023 @ 14:38
    Abdulaziz
    Hello Nick 🙂
    Have you made sure the Document Type is a child of the Home node?
    May 12, 2023 @ 15:01
    Nick Markham
    Thanks for getting back to me and helping...
    I've just made sure the Document Type is a child of the Home node as it wasn't and can create a page from the doc type under content-->home.
    I'm still getting a 404 though when navigating to the page using the link.
    Any idea why please?
    Cheers, Nick. enter image description hereenter image description here
    May 12, 2023 @ 15:15
    Nick Markham
  • Brian Milinski 42 posts 165 karma points
    May 12, 2023 @ 18:20
    Brian Milinski
    The error shows "No Template Exists", can you please copy and paste the template code for the "Terms" template that you have created? - I would look at the Razor View as a start.
  • Yaco Zaragoza 88 posts 363 karma points
    May 12, 2023 @ 18:39
    Yaco Zaragoza
    I am not sure how much this matters but I think your template might start with a lower case instead of a capital letter.
    May 13, 2023 @ 21:18
    Abdulaziz
    Looks like the Terms Document Type you have does not have a template. As it says in the 404 error you're getting.
    Do you have a template in your Settings section for the Terms Doc type?
