  • Vasco Horta e Costa 18 posts 119 karma points
    May 30, 2023 @ 09:49
    Vasco Horta e Costa
    Webp images exported from Photoshop throws and errror while uploading
    Hi Guys,
    All our .webp images when exported from Photoshop are throwing an error and consequently not updating image dimensions and size.
    Did any of you have this issue?
    SixLabors.ImageSharp.ImageFormatException: Unexpected chunk followed VP8X header at SixLabors.ImageSharp.Formats.Webp.WebpThrowHelper.ThrowImageFormatException(String errorMessage) at SixLabors.ImageSharp.Formats.Webp.WebpDecoderCore.ReadVp8XHeader() at SixLabors.ImageSharp.Formats.Webp.WebpDecoderCore.ReadVp8Info() at SixLabors.ImageSharp.Formats.Webp.WebpDecoderCore.Identify(BufferedReadStream stream, CancellationToken cancellationToken) at SixLabors.ImageSharp.Formats.ImageDecoderUtilities.Identify(IImageDecoderInternals decoder, Configuration configuration, Stream stream, CancellationToken cancellationToken) at SixLabors.ImageSharp.Formats.Webp.WebpDecoder.Identify(Configuration configuration, Stream stream, CancellationToken cancellationToken) at SixLabors.ImageSharp.Image.InternalIdentity(Stream stream, Configuration config, CancellationToken cancellationToken) at SixLabors.ImageSharp.Image.<>cDisplayClass108_0.0(Stream s) at SixLabors.ImageSharp.Image.WithSeekableStream[T](Configuration configuration, Stream stream, Func`2 action) at SixLabors.ImageSharp.Image.Identify(Configuration configuration, Stream stream, IImageFormat& format) at SixLabors.ImageSharp.Image.Identify(Configuration configuration, Stream stream) at Umbraco.Cms.Infrastructure.Media.ImageSharpDimensionExtractor.GetDimensions(Stream stream) at Umbraco.Cms.Core.Media.UploadAutoFillProperties.SetProperties(IContentBase content, ImagingAutoFillUploadField autoFillConfig, String filepath, Stream filestream, String culture, String segment) at Umbraco.Cms.Core.Media.UploadAutoFillProperties.Populate(IContentBase content, ImagingAutoFillUploadField autoFillConfig, String filepath, String culture, String segment)
  • Nidhi 34 posts 156 karma points
    Sep 26, 2023 @ 19:37
    Nidhi
    Hey
    Did you find a solution to this problem. ? I think we too are experiencing the same problem.
    Oct 18, 2023 @ 16:16
    Vasco Horta e Costa
    Nop, no solution yet
  • Huw Reddick 1932 posts 6722 karma points MVP 3x c-trib
    Oct 20, 2023 @ 07:34
    Huw Reddick
    are these animated images?
    Oct 20, 2023 @ 08:11
    Vasco Horta e Costa
    Hi There,
    No, I have an example here:
    https://github.com/umbraco/Umbraco-CMS/issues/15007
    Oct 20, 2023 @ 08:17
    Nidhi
    We upgraded Umbraco to the latest 12.2 and webp format just worked. So may be upgrading umbraco can solve the issue.
    Oct 20, 2023 @ 08:29
    Vasco Horta e Costa
    Unfortunately, I can only run LTS versions, in V12 Umbraco updated SixLabors.ImageSharp package.
    Oct 20, 2023 @ 08:32
    Huw Reddick
    yes, it works in v12, you could try manually updating the SixLabors package to see if that works for you
    Oct 20, 2023 @ 08:44
    Vasco Horta e Costa
    Gives me this error, seems it has aditional dependencies.
    System.TypeLoadException: Could not load type 'SixLabors.ImageSharp.IImageInfo' from assembly 'SixLabors.ImageSharp, Version=3.0.0.0, Culture=neutral, PublicKeyToken=d998eea7b14cab13'.
