  • Wajert 2 posts 22 karma points
    May 31, 2023 @ 09:48
    Wajert
    Usync using nodeID instead of Guid when using macro with MultinodeTreepicker is there a workaround?
    I'm using a macro that includes a parameter operating with a MultiNodeTreePicker. This is being utilized in a rich text editor. I exported a file from my live website to my local environment using uSync. The issue lies in Umbraco propensity to create new NodeIDs for each environment. The uSync file refers to a NodeID, not a Guid. I'm curious as to why uSync doesn't utilize Guid for this purpose. Is there a known workaround for this issue?
  • Marc Goodson 2157 posts 14434 karma points MVP 9x c-trib
    Jun 03, 2023 @ 10:47
    Marc Goodson
    Hi Wajert
    My guess is that the MultipleMediaPicker when used as a ParameterEditor, doesn't have its idType set to 'udi'
    https://github.com/umbraco/Umbraco-CMS/blob/9bafdbd992534c14d8ee8fad53c700258c15b3f3/src/Umbraco.Core/PropertyEditors/ParameterEditors/MultipleMediaPickerParameterEditor.cs#L18
    and so stores the picked items as integer Ids...
    Workaround wise, you could maybe create a new custom property editor by copying the core implementation from the link above or maybe inheriting from it but giving it a new name and ensuring to add the necessary configuration to make it store Udis:
    eg
     DefaultConfiguration.Add("idType", "udi");
    USync would likely be clever enough to work with the Udis...
    regards
    Marc
  • Chris Van Oort 110 posts 371 karma points
    Aug 02, 2023 @ 16:52
    Chris Van Oort
    Were you ever able to find a solution to this? Running into the same issue -- Usync 10 + Umbraco 10
    Oct 17, 2023 @ 12:36
    Wajert
    Hi Chris,
    Sorry we haven't been able to find a solution to the issue so far. We haven't had the time to dig deep into it, and the problem hasn't been urgent enough to prioritize for us.
    Oct 17, 2023 @ 14:21
    Chris Van Oort
    All good -- appreciate the reply. We changed our design to just use "single" versions of tree picker and media picker. We dug deep into the uSync code and there's something weird happening where it wouldn't resolve the IDs to UDIs on the "multi" versions. This is the only way we could reliably get Usync to gather and ship changes.
