  • Bo Jacobsen 610 posts 2409 karma points
    Jun 02, 2023 @ 11:40
    Bo Jacobsen
    How to use ITemplateRenderer.RenderAsync with IPublishedContentWrapped served through a RenderController
    Hi all.
    Using Umbraco CMS 10.5.1, we are getting html from a Content node, using ITemplateRenderer.RenderAsync to validate the html.
    It fails if we are using a custom controller inherited by RenderController with a custom entity inherited by PublishedContentWrapped.
    It does not initiate the RenderController at all. It's like its looking at the view and decide it cannot bind the models.
    using (var stringWriter = new StringWriter())
        await _templateRenderer.RenderAsync(pageId: 1010, altTemplateId: null, writer: stringWriter);
        return stringWriter.ToString();
    public class ListViewModel : PublishedContentWrapped
        public ListViewModel(IPublishedContent content, IPublishedValueFallback publishedValueFallback) : base(content, publishedValueFallback) { }
        public List<IPublishedContent>? Results { get; set; }
        public string? Query { get; set; }
        public IHtmlContent? Pagination { get; set; }
    @inherits Umbraco.Cms.Web.Common.Views.UmbracoViewPage<ListViewModel>
        Layout = "layout.cshtml";
    <section>
        <div>
            @await Html.PartialAsync("results", Model)
            @if (Model.Pagination != null)
                @Model.Pagination
    </section>
    The error we are getting is:
    Umbraco.Cms.Web.Common.ModelBinders.ModelBindingException: 'Cannot bind source content type Umbraco.Cms.Web.Common.PublishedModels.PublicationsArea to model type xxx.xxx.xxx.ListViewModel.
    The source is a ModelsBuilder type, but the view model is not. The application is in an unstable state and should be restarted.'
    Then if we disable the ModelsBuilder, then we get this error:
    Umbraco.Cms.Web.Common.ModelBinders.ModelBindingException: 'Cannot bind source content type Umbraco.Cms.Infrastructure.PublishedCache.PublishedContent to model type xxx.xxx.xxx.ListViewModel.'
    What are we missing?
    Jun 06, 2023 @ 10:51
    Bo Jacobsen
    We have also tried to inherit the ListViewModel with ContentModel, and that gives the same error.
    public class ListViewModel : ContentModel
        public ListViewModel(IPublishedContent content) : base(content) { }
