How to tell where a partial view is in the hierarchy and conditionally apply styles
I have a TextBlock partial that renders some rich text.
A TextBlock can appear in one of two places in the page hierarchy.
1: Page Level, so the hierarchy would be
Page<-BlockList<-BlockListItem<-TextBlock
Inside a more complicated nested component structure like
Page <-BlockList<-Accordion<-TextBlock
The task at hand is to conditionally add a CSS class to the TextBlock when the TextBlock is at Page Level not at the other level.
I believe that the Ancestor() or AncestorsOrSelf() methods might let me test the immediate parent nodes or get at the -2 node assuming that's the page level node, but I just can't seem to call these methods in the debugger.
In the TextBlock partial when I debug,
Model is of type BlockListItem
I've imported Umbraco.Cms.Core.Models.PublishedContent at the top of the partial assuming that's where Ancestor or AncestorsOrSelf come from.
When I tried to access Model.Ancestor() or Model.Content.Ancestor() in the debugger, I got the error "IPublishedElement does not contain definition for Ancestor and the best extension method overload requires a receive of type IPublishedContent.
Some I'm guessing I need a cast maybe or I just can't do this from a partial.
Unfortunately it would be quite a challenge to handle it in the manner you are after. This is because BlockList items have no knowledge of their parent/ancestors as they aren't part of a "tree" persay.
However, as Huw mentions, this would be better handled purely in CSS.
For example, your pages could have a "Page" class added to the body,
Then all your Rich Text Blocks could have "Text-Block" as a class.
Accordion blocks could then have a "Accordion-Block" class.
using this you could use the CSS principles to apply styles to the different text-blocks without the need to add additional classes.
you should be able to do this purely with css selectors no need to involve code.
Hi Ian,
For example, your pages could have a "Page" class added to the body, Then all your Rich Text Blocks could have "Text-Block" as a class. Accordion blocks could then have a "Accordion-Block" class.
