  • Nez 8 posts 38 karma points
    Jun 16, 2023 @ 20:18
    Nez
    Block Grid. How to make it mobile friendly?
    when using block grid. How can I make it mobile friendly? Once you are on mobile view, the spacing looks weird with white spaces everywhere.
    There's not really a tutorial for it either.
    Is the only way to do this is using @media and change umb-block-grid__layout-item directly?
    Thank you.
  • Robert Johnston 16 posts 106 karma points
    Jun 16, 2023 @ 22:06
    Robert Johnston
    I'm sure there are better ways to do this but here is the css I use:
    .umb-block-grid__layout-container {
        position: relative;
        display: grid;
        grid-template-columns: repeat(var(--umb-block-grid--grid-columns, 1), minmax(0, 1fr));
        grid-gap: 0px;
        grid-auto-flow: row;
        grid-auto-rows: minmax(50px, -webkit-min-content);
        grid-auto-rows: minmax(50px, min-content);
    .umb-block-grid__layout-item {
        position: relative;
        /* For small devices we scale columnSpan by three, to make everything bigger than 1/3 take full width: */
        grid-column-end: span min(calc(var(--umb-block-grid--item-column-span, 1) * 3), var(--umb-block-grid--grid-columns));
        grid-row: span var(--umb-block-grid--item-row-span, 1);
    .umb-block-grid__layout-item[data-force-left] {
        grid-column-start: 1;
    .umb-block-grid__layout-item[data-force-right] {
        grid-column-start: calc(1 + var(--umb-block-grid--grid-columns) - var(--umb-block-grid--item-column-span));
    .umb-block-grid__area-container, .umb-block-grid__block--view::part(area-container) {
        position: relative;
        display: grid;
        grid-template-columns: repeat(var(--umb-block-grid--area-grid-columns, var(--umb-block-grid--grid-columns, 1)), minmax(0, 1fr));
        grid-gap: 0px;
        width: 100%;
    .umb-block-grid__area {
        position: relative;
        grid-row: span var(--umb-block-grid--area-row-span, 1);
    @media (min-width:1024px) {
            grid-column-end: span var(--umb-block-grid--item-column-span, 1);
            grid-column-end: span var(--umb-block-grid--area-column-span, 1);
    @media (max-width:600px) {
        .umb-block-grid__area-container {
            --umb-block-grid--area-grid-columns: 1!important;
    I have this in a separate css (blockgridlayout.css) file I reference in my master template.
    Jun 20, 2023 @ 16:03
    Nez
    I see, thank you! I will def try it out :D
