  • Ian 3 posts 73 karma points notactivated
    Jun 22, 2023 @ 07:50
    Ian
    How to conditionally add to the Master head based on environment eg Dev Test etc.
    I've got a requirement to add script to the head of the Master.cshtml file, but not if the environment is development, so I'm wondering how to do this.
    I suspect there must be something built in to do this, I've looked I just can't find it.
    In startup.cs, I see IWebHostEnvironment offers an EnvironmentName property, but that's in the apps bootstraping code.
  • Daniel 18 posts 108 karma points
    Jun 22, 2023 @ 08:04
    Daniel
    Hi.
    Some different ways to approached this.
    I think I would solve this by using the appsetting. Read more about it here .
    You can get a property from the cshtml using the injector like this:
    @inject Microsoft.Extensions.Configuration.IConfiguration Configuration
    var Env = Configuration["Enviroment:Production"];
