Recently i set up Umbraco 11 on a blazor project, but .Value does not work. Even tho i have created a document type and added the alias as "body".
@inherits UmbracoViewPage; @using ContentModels = Umbraco.Cms.Web.Common.PublishedModels; @using Umbraco.Cms.Web.Common.Views; @{ Layout = null; } <p>test</p> @Model.Value("body")
The Error i get:
'IPublishedContent' does not contain a definition for 'Value' and the best extension method overload 'HtmlHelperValueExtensions.Value(IHtmlHelper, string)' requires a receiver of type 'IHtmlHelper'
The Value method is defined in the Umbraco.Extensions namespace. Can you verify that you have @using Umbraco.Extensions in /Views/_ViewImports.cshtml?
Value
Umbraco.Extensions
The Error i get:
The
Valuemethod is defined in theUmbraco.Extensionsnamespace. Can you verify that you have@using Umbraco.Extensionsin/Views/_ViewImports.cshtml?is working on a reply...
