  • David Jazbec 23 posts 145 karma points
    Jun 30, 2023 @ 20:28
    David Jazbec
    Hide Label above Layout Block in backoffice
    Hi lads,
    im exploring the Grid Block editor, and i really like it. I installed the demo umbDemoBlocks that come with it. The "Two Columns Block" that comes with it does not show any label above it in the Backoffice but my own Three Columns Block does and i cannot find out where can i disable it?
    Jul 01, 2023 @ 10:44
    Marc Goodson
    Hi David
    It's because in the demo, those two section layouts have a custom view...
    If you click on the Block Grid Data Type in the settings section
    Click on the Two-Column section, and then the 'Advanced' tab in top right hand corner
    You'll see a path to a custom view
    ~/App_Plugins/My.BlockGridViews/section.html
    which controls how this section looks in the backoffice. and if you have a look in the view, you'll see no attempt to render the label above.
    But if you create a new layout and don't specify a custom view, the default implementation of the block list is to put the label above (a bit like the old grid implementation in earlier versions of Umbraco)
    regards
    Marc
    Jul 01, 2023 @ 19:41
    David Jazbec
    Hi Marc,
    thank you for your response.
    it does make sense that the blocks are using different custom views. but the demo block uses this view:
    ~/App_Plugins/Umbraco.BlockGridEditor.DefaultCustomViews/umbBlockGridDemoTwoColumnLayoutBlock.html
    and i dont even this folder/file in the "App_Plugins" Folder, which lets me think that the file is actually being pulled from somewhere else. Could this be the case or am i just blind?
    Jul 01, 2023 @ 21:08
    Marc Goodson
    Hi David
    My bad! I think i'm looking at an early grid demo site that was released for UK fest and can see there is an updated one now for cg23
    https://github.com/kjac/UmbracoBlockGridCG23/blob/main/App_Plugins/My.BlockGrid/Views/section.html
    Is this the file you are looking for?
    https://github.com/umbraco/Umbraco-CMS/blob/1d14158d82ce5d9e3ed9766e8e11faddb455be19/src/Umbraco.Cms.StaticAssets/wwwroot/App_Plugins/Umbraco.BlockGridEditor.DefaultCustomViews/umbBlockGridDemoTwoColumnLayoutBlock.html#L2
    Looks like it's shipped as a static asset in a razor class library..
    Regards
    Marc
    Jul 02, 2023 @ 10:26
    David Jazbec
    Hi Marc,
    this is it!
    Copied it to my Custom views & using it with my Layouts, works wonderfully.
    Thank you!
    Dave
