Umbraco Workflows for project's export without a database connection
Hi.
I noticed an issue (I'm not sure if that's an bug but I think it's worth asking) when a project on premise with Umbraco workflows is published.
When a VS project is published to a new environment with an empty connection string , it create a new Umbraco project where the administrator has to populate the DB connection details through the Umbraco setup window; however if the project includes Umbraco Workflows it doesn't even display the Umbraco setup window because U-Workflows tries to connect to a DB that doesn't exist yet, so it throws an error. So I have to remove the U-Workflows package, run the Umbraco set up window, add the DB details and once completed I had to add U-workflows.
It's not a big deal but I think it's worth mentioning in case this can resolve for future releases
Hi. I noticed an issue (I'm not sure if that's an bug but I think it's worth asking) when a project on premise with Umbraco workflows is published.
When a VS project is published to a new environment with an empty connection string , it create a new Umbraco project where the administrator has to populate the DB connection details through the Umbraco setup window; however if the project includes Umbraco Workflows it doesn't even display the Umbraco setup window because U-Workflows tries to connect to a DB that doesn't exist yet, so it throws an error. So I have to remove the U-Workflows package, run the Umbraco set up window, add the DB details and once completed I had to add U-workflows. It's not a big deal but I think it's worth mentioning in case this can resolve for future releases
