  • Thomas 43 posts 123 karma points
    Jul 21, 2023 @ 14:36
    Thomas
    Umbraco composer in razor class library
    Hi, I have razor class library and inside this I have DI registered in Umbraco builder. This razor class library is dynamically refer in main web application. When I run web application the razor class library DI is not resolved
    Anyone have idea to handle this?
    Jul 21, 2023 @ 16:56
    Huw Reddick
    how exactly are registering it?
    Jul 21, 2023 @ 17:35
    Thomas
    Hi Reddick,
    The dependencies are registered in razor class library
      public class FileWatcherComposer : IComposer
        public void Compose(IUmbracoBuilder builder)
            builder.Services.AddScoped<IFileWatcherService, FileWatcherService>();
    Jul 21, 2023 @ 18:06
    Huw Reddick
    That should be fine, what is the error you are getting, if any?
    Jul 21, 2023 @ 18:10
    Thomas
    Its showing Unable to resolve the dependency IFileWatcherService when its invoked But its working when the razor class library is refer in main web app directly (add project reference). But its not working when its loaded at runtime (dynamically loaded assembly - ApplicationPartManager)
    Jul 22, 2023 @ 07:20
    Huw Reddick
    If you are loading at runtime then the composer will not run. Are you loading at run time for a specific reason? If so you will need to register the service differently
    Jul 22, 2023 @ 10:18
    Thomas
    Yes, When I run my web application it should read (dynamically loaded) the razor class library dll and update the Umbraco web app to use external app.
    Jul 22, 2023 @ 15:33
    Jul 24, 2023 @ 12:23
