  • _R 13 posts 143 karma points
    Jul 25, 2023 @ 08:28
    _R
    GetAllCultures Failes with 'Culture is not supported.'
    Currently we struggle with the following API call which is performed by Umbraco: umbraco/backoffice/umbracoapi/language/GetAllCultures
    The response of the call is:
        "ExceptionMessage": "Culture is not supported. (Parameter 'name')\r\naa is an invalid culture identifier.",
        "ExceptionType": null,
        "StackTrace": null
    This call should return all available cultures like:
        "aa": "Afar",
        "aa-DJ": "Afar (Djibouti)",
        "aa-ER": "Afar (Eritrea)",
        "aa-ET": "Afar (Ethiopia)",
        "af": "Afrikaans",
        "af-NA": "Afrikaans (Namibia)",
        "af-ZA": "Afrikaans (South Africa)",
        "agq": "Aghem",
        "agq-CM": "Aghem (Cameroon)",
        "ak": "Akan",
        "ak-GH": "Akan (Ghana)",
        Etc.....
    As far as I can see in the controller this code should be executed and nothing more right?:
    [HttpGet]
    public IDictionary<string, string> GetAllCultures()
        => CultureInfo.GetCultures(CultureTypes.AllCultures).DistinctBy(x => x.Name).OrderBy(x => x.EnglishName).ToDictionary(x => x.Name, x => x.EnglishName);
    How can this controller endpoint ever fail?
    Because it cannot retrieve any culture, we also cannot add any new ones via Umbraco. Currently we have one culture configured in the DB and it looks like this:
    "id","languageISOCode","languageCultureName","isDefaultVariantLang","mandatory","fallbackLanguageId"
    1,en-US,English (United States),0,0,
  • Huw Reddick 1932 posts 6722 karma points MVP 3x c-trib
    Jul 28, 2023 @ 15:57
    Huw Reddick
    We just got the exact same issue on a site we are upgrading, what version of Umbraco are you working with?
    Jul 31, 2023 @ 14:20
    _R
    Currently we are at version Umbraco version 10.5.0 in which we encountered this issue.
    Jul 31, 2023 @ 14:44
    Huw Reddick
    Hi _R, could you confirm what server OS you are using? so far I have only encountered the problem on Server2012
    Aug 02, 2023 @ 09:19
    _R
    Hey Huw,
    True, we encountered the problem on our Windows Server 2012 R2 Datacenter.
    For now it looks like it has some trouble extracting cultures using IIS globalization:
  • TiaNewman 2 posts 71 karma points
    Aug 02, 2023 @ 09:46
    TiaNewman
    Thanks for the information. MyTHDHR.com
  • Mohammed BOUTEBEL 64 posts 103 karma points
    Sep 27, 2023 @ 13:39
    Mohammed BOUTEBEL
    Hi.
    We noticed the same behavior on a Umbraco 12.1.1 installed and the package uskinnedSiteBuilder installed.
    Apr 12, 2024 @ 13:49
    Huw Reddick
    this is/was an OS issue, do you know what OS your site is running on?
