Way to run Umbraco CMS as headless on Next or Astro?
Now that Umbraco 12 can do headless, I would like to explore the possibility of running the frontend fully under the Node.js runtime, but still staying on the same solution so I don't have to separate the frontend from Umbraco.
Has anyone tried to run a Node.js process under .NET so that it could actually run the frontend in Next.js or Astro, and when typing example.com/umbraco/, it loads the CMS normally?
