  • Thobias 4 posts 74 karma points
    Aug 17, 2023 @ 10:34
    Thobias
    SEOChecker and Umbraco Forms are not working together - duplicated endpoint
    I get stuck on something weird behavior.
    SEOChecker: 10.0.4 Umbraco: 10.5 Umbraco Forms: 10.2
    The problem is, the POST request ended in an exception.
    InvalidOperationException: The following endpoints with a duplicate endpoint name were found.
    Endpoints with endpoint name 'robotstxtroute':
    Route: robots.txt
    Route: robots.txt
    Endpoints with endpoint name 'xmlsitemaproute':
    Route: sitemap.xml
    Route: sitemap.xml
    Endpoints with endpoint name 'xmlsitemaplocaleroute':
    Route: {localePath}/sitemap.xml
    Endpoints with endpoint name 'sitemapindexroute':
    Route: sitemapindex.xml
    The controller eg. "SEOCheckerRobotsTxtController" is added twice on a POST request, found by debugging EndpointNameAddressScheme.Initialize() method.
    I figured out that this is happening when the "ufprt" is given in the payload.
    This error is shown on BeginUmbracoForm with a SurfaceController as action too.
    Has anyone an idea?
  • Richard Soeteman 4031 posts 12817 karma points MVP
    Aug 23, 2023 @ 06:54
    Richard Soeteman
    Not sure what to do? I register this once during startup of the app.
    Aug 23, 2023 @ 07:54
    Thobias
    What exactly do you register during startup?
    Aug 23, 2023 @ 07:57
    Richard Soeteman
    Using a composer in Umbraco this is registered
      applicationBuilder.UseEndpoints(endpoints =>
                        endpoints.MapControllerRoute(
                          "robotstxtroute",
                          "robots.txt",
                          new { Controller = "SEOCheckerRobotsTxt", Action = "Index" });
                            "xmlsitemaproute",
                            "sitemap.xml",
                            new { Controller = "SEOCheckerXmlSitemap", Action = "Index" });
                          "xmlsitemaplocaleroute",
                          "{localePath}/sitemap.xml",
                         "sitemapindexroute",
                         "sitemapindex.xml",
                         new { Controller = "SEOCheckerXmlSitemap", Action = "FileIndex" });
    Aug 23, 2023 @ 08:06
    Thobias
    I tried this but the same error again.
    Did you test it with Umbraco Forms and submit a form?
    Aug 23, 2023 @ 08:22
    Richard Soeteman
    I just did,
    No errors on submit, no errors in log.
    Aug 23, 2023 @ 08:30
    Thobias
    I figured out, what is causing the problem.
    The problem was i used the WidthMiddleware instead of WithCustomMiddleware.
    .WithCustomMiddleware(u =>
                    u.RunPrePipeline();
                    u.RegisterDefaultRequiredMiddleware();
                    u.RunPostPipeline();
                    u.UseBackOffice();
                    u.UseWebsite();
    WithMiddleware is calling Pre and Post pipelines aswell, WithCustomMiddle not.
    Aug 23, 2023 @ 08:32
    Richard Soeteman
    Great it's solved
