Site information:
http://mosbjergtolne.dk.web12.curanetserver.dk/
Version Umbraco version 7.15.10 assembly: 1.0.8321.19798
iam a ware that it is a old version but it is not posible to opgrade server to handel version 8 ore up.
iam making at page for our local town.
i hvae design up the page in html and it looks god now the hard part..
i love to get it to be lige mya html but i cant get my head around it
<!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " "> ]>
<xsl:stylesheet
version="1.0"
xmlns:umbraco.library="urn:umbraco.library" xmlns:Examine="urn:Examine"
exclude-result-prefixes="msxml umbraco.library Examine ">
<!-- Input the documenttype you want here -->
<!-- Typically '1' for topnavigtaion and '2' for 2nd level -->
<!-- Use div elements around this macro combined with css -->
<!-- for styling the navigation -->
<xsl:variable name="level" select="1"/>
<xsl:template match="/">
<!-- The fun starts here -->
<ul class="nav navbar-nav navbar-left">
<li>
<a href="/" class="">Forside</a>
</li>
<xsl:for-each select="$currentPage/ancestor-or-self::* [@isDoc and @level=$level]/* [@isDoc and string(umbracoNaviHide) != '1']">
<li class="dropdown">
<xsl:if test="$currentPage/ancestor-or-self::*/@id = current()/@id">
<!-- we're under the item - you can do your own styling here -->
<xsl:attribute name="class">active</xsl:attribute>
</xsl:if>
</a>
<ul class="dropdown-menu">
</ul>
</li>
</xsl:for-each>
</ul>
</xsl:template>
</xsl:stylesheet>
Top Navigation whit subpages shown
Hey.
Site information: http://mosbjergtolne.dk.web12.curanetserver.dk/ Version Umbraco version 7.15.10 assembly: 1.0.8321.19798 iam a ware that it is a old version but it is not posible to opgrade server to handel version 8 ore up.
my meny is like this in html:
nad loks like this https://i.imgur.com/hpvsa7S.png
i have this topnavigation macro. i use to use. but i cant figer out how to get it to sho the subpages..
as you se them her.. https://i.imgur.com/kyCNsKj.png
is thear eny one thar can help me. ?
Hi Michael,
I wrote a bunch of XSLT once to help with this that you might find useful:
https://github.com/greystate/Greystate-XSLT-Helpers/tree/master/navigationhelper
Alternatively, could you maybe post the general structure of the completed HTML that you need to generate? (Starting from the
<ul class="nav (etc.)">)/Chriztian
