But when I try to run dotnet run I get following error:
Unhandled exception. System.ArgumentNullException: Value cannot be null. (Parameter 'factory')
at System.Data.Common.DbProviderFactories.RegisterFactory(String providerInvariantName, DbProviderFactory factory)
at Umbraco.Cms.Persistence.SqlServer.UmbracoBuilderExtensions.AddUmbracoSqlServerSupport(IUmbracoBuilder builder)
at Umbraco.Cms.Persistence.SqlServer.SqlServerComposer.Compose(IUmbracoBuilder builder)
at Umbraco.Cms.Core.Composing.ComposerGraph.Compose()
at Umbraco.Cms.Core.DependencyInjection.UmbracoBuilderExtensions.AddComposers(IUmbracoBuilder builder)
at nt.web.Startup.ConfigureServices(IServiceCollection services) in /home/jp/code/docker/src/nt.web/Startup.cs:line 32
at System.RuntimeMethodHandle.InvokeMethod(Object target, Void** arguments, Signature sig, Boolean isConstructor)
at System.Reflection.MethodInvoker.Invoke(Object obj, IntPtr* args, BindingFlags invokeAttr)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at Microsoft.AspNetCore.Hosting.ConfigureServicesBuilder.InvokeCore(Object instance, IServiceCollection services)
at Microsoft.AspNetCore.Hosting.GenericWebHostBuilder.UseStartup(Type startupType, HostBuilderContext context, IServiceCollection services, Object instance)
at Microsoft.Extensions.Hosting.HostBuilder.InitializeServiceProvider()
at Microsoft.Extensions.Hosting.HostBuilder.Build()
at Umbraco.Cms.Web.Common.Hosting.UmbracoHostBuilderDecorator.Build()
at nt.web.Program.Main(String[] args) in /home/jp/code/docker/src/nt.web/Program.cs:line 6
I was trying to run just with a default settings as per documentation. I tried in Linux Mint desktop and on Docker (Ubuntu) under it and both stopped on the same error. Perhaps I am missing some libraries on dotnet? I am going to give another spin on this in few days.
I had issues with plugins in the backoffice on the Pi, so ended up having to publish in debug rather than release mode (something to do with the smidge minification)
Umbraco on Linux is not running
I am running the latest dotnet SDK (7.0.110) and installed Umbraco as per Install using .NET CLI documentation
dotnet runI get following error:Anyone knows what am I missing?
Did you find a solution to this? I am having the same problem.
No, it seems Umbraco is not running under Linux. It would be intresting to hear if anyone has been able to run it?
Funny thing is, that the same project deployed to my linux server actually works without problem.
Should run fine on Linux, I have it running on a raspberry pi.
The error sounds database related, what database are you trying to use?
