  • mizzle 91 posts 326 karma points
    Oct 09, 2023 @ 20:31
    mizzle
    When using the Multi-Url Picker, is there a way to stop it from auto-filling the Link Title field?
    The structure of the Multi Url Picker is strange, in that you can specify the Link Title field before selecting the Umbraco node or piece of media you're linking to, which then changes the already-specified Link Title field. So you have to make sure to go back and change it to what you'd originally put before saving. Not very efficient.
    In V8, I could edit the structure of the Multi Url Picker pop-out so that the Link Title (which is used for button text, link text, etc.) came after the node/media selection sections and could be the last change before publishing. This doesn't appear to be possible for V9+.
    Is there a way to stop the auto-fill instead?
    Barring that, is there a way to edit the Umbraco backend style/structure the way I used to with version 8?
    Oct 18, 2023 @ 20:09
    Marc Goodson
    2
    Hi mizzle
    Not an immediate fix, but just wanted to say this has been a bugbear of soooo many editors over the years... And thanks for highlighting the issue again....
    I have suggested a PR which might make this slightly less annoying...
    https://github.com/umbraco/Umbraco-CMS/pull/15003
    Not a perfect fix, but should reduce some editor pain...
    Regards
    Marc
