  • Jason Kunkle 13 posts 123 karma points
    Oct 12, 2023 @ 14:34
    Jason Kunkle
    Issue with using an if statment to conditionally display a header in a template
    In my template I'm trying to check if my header content item has a value. If it has a value I want it to be displayed as an h2, if it does not have a value I don't want to display it. I tried the code below but it does not work. What would be the proper syntax for this?
    var leftHeader = item.Value<IPublishedContent>("interiortLeftHeader");
    @if(leftHeader != ""))
    {   <h2>@item.Value("interiortLeftHeader")</h2>   }
    Thank you.
    Oct 12, 2023 @ 19:01
    Marc Goodson
    Hi Jason
    It depends what type of property editor is, I'm going to assume it is a textstring as tgat would be normal for a header... Then
    @if (item. HasValue("interiorLeftHeader")) { <h2>@(item.Value<string>("interiortLeftHeader")) </h2> }
    Would I think be what you are after?
    Regards
    Marc
    Oct 12, 2023 @ 19:05
    Jason Kunkle
    That worked perfectly!
    Thank you!
    Oct 12, 2023 @ 19:12
    Marc Goodson
    That's good, because I was typing on my mobile and it took ages to escape the code sample with & lt; etc!
