I am in the middle of upgrading a site from Umbraco version 8 to 10 and I'm having issues with umbraco forms.
After updating I cannot see any forms even when I am logged in as administrator. I can create a new form and save it and see the new entry in the table UFForms
Before switching to Forms 10.5.1 I have updated to 8.13.1 and set that forms should be saved in the database. The health check is all green for forms both before and after.
The permissions are set to all access to my user.
On thing that might be related is that when I try to update the permissions there is an error (but the table UFUserSecurity is updated correctly):
Microsoft.Data.SqlClient.SqlException (0x80131904): Conversion failed when converting the nvarchar value '−1' to data type int.
After some more investigation I have noticed something weird. It looks like a bug in Umbraco Forms?
When I create new form, two entries are added to UFUserFormSecurity. One for the user -1 which is correct, and one for the user −1 (where the dash is a unicode minus sign!) which is probably wrong.
But I can still not see the form as the admin user, even after removing the bad row. Other users can see the forms.
Edit: After changing the language for the admin from Swedish to English I can now see all the forms. So probably a bug in Umbraco.Forms?
Issues when upgrading Umbraco forms from 8 to 10
Hello!
UFFormsBefore switching to Forms 10.5.1 I have updated to 8.13.1 and set that forms should be saved in the database. The health check is all green for forms both before and after.
UFUserSecurityis updated correctly):Update:
UFUserFormSecurity. One for the user-1which is correct, and one for the user−1(where the dash is a unicode minus sign!) which is probably wrong.But I can still not see the form as the admin user, even after removing the bad row. Other users can see the forms.
