  • mohd iliyaj 8 posts 77 karma points
    Nov 06, 2023 @ 10:55
    mohd iliyaj
    Design the language dropdown using the Umbraco language varients
    Hello Everyone,
    I'm designing a umbraco project and I want one dropdown in navbar with different languages when user selects a language content should be changed to selected language, If user return to previous language then content should be revert to previous language. Can anyone help to resolve this issue as much as possible, Please don't share any document because I have gone through all the document but I can't find the solution. Please provide me some steps to resolve this problem.
    Thank you,
    Iliyaj
    Nov 06, 2023 @ 11:43
    Huw Reddick
    this should work. It renders a dropdown.
    @inherits Umbraco.Cms.Web.Common.Views.UmbracoViewPage<IPublishedContent>
    @using System.Globalization;
    @using Umbraco.Cms.Core.Models
    @using UmbracoProject.Core.Models
        var currentPage = Model.Url();
        var cultureList = Model.Cultures.ToList();
        var languagePickerLinks = new List<CultureModel>();
        @foreach (var culture in cultureList) {
            var langName = CultureInfo.CreateSpecificCulture(culture.Value.Culture);
            var link = new CultureModel {
                Url = Model.Url(culture.Value.Culture),
                Culture = culture.Value.Culture,
                LangName = langName.NativeName.Split(" ")[0]
            languagePickerLinks.Add(link);
        if (cultureList.Count > 1) {
            <div class="lang-switch">
                    <select id="lang-switch"  asp-for="@currentPage" onchange="if (this.value) window.location.href=this.value">
                        @foreach (var culture in languagePickerLinks) {
                            <option value="@culture.Url">@culture.LangName</option>
                    </select>
    The CultureModel is
    public class CultureModel {
        public string? Url { get; set; }
        public string? Culture { get; set; }
        public string? LangName { get; set; }
