  • Sebastian Dammark 583 posts 1407 karma points
    Dec 01, 2023 @ 09:38
    Sebastian Dammark
    Required fields area saved regardless of validation
    Do others experience that required fields are saved regardless of validation ? In my case it happens in Block List ?
    Video: https://jottacloud.com/s/0501e62f594be004bfda8ef732764b9338d
  • Nik 1625 posts 7295 karma points MVP 8x c-trib
    Dec 01, 2023 @ 09:55
    Nik
    Yes, I believe that this is "intentional", you can save it, but you can't publish if the validation fails. It is so you can come back to it to fix issues.
    I could well be wrong though.
    Nik
    Dec 01, 2023 @ 10:00
    Sebastian Dammark
    But I am publishing, hence the big green button :)
    Dec 01, 2023 @ 10:37
    Nik
    101
    Except I don't think you are. You are doing a "Save and Publish", which only does the publish part if the validation passes.
    It does the "Save", validates the page data, and then fails so doesn't publish showing you the red error notification about validation.
    Are you seeing the missing field no longer showing on the front end? Because that would indicate if the publish is still triggering. Does that make sense?
    Nik
    Dec 01, 2023 @ 10:51
    Sebastian Dammark
    2
    Ahhh ... you're absolutely right.
    That's gonna require all my diplomatic skills to explain that to the client :)
    Dec 01, 2023 @ 13:28
    Sebastian Dammark
    Hi again Nik,
    The bonus question is then, why is there a difference on how the fields validate ?
    In this example I'm using a Umbraco.MultiUrlPicker, which actually prevents the page from saving before it's tries to publish.
    Link to video: https://jottacloud.com/s/050cfd38f3fe2cb4ef988613c7b9f6c56f7
    Dec 01, 2023 @ 17:06
    Nik
    That to me would be a bug in the CMS, something about how that property renders when in an overlay or something is validated at a different point.
    I would raise it on GitHub :-)
