Is there a better view to compare versions of a content?
If I open a content and go to Info->Rollback and select a previous version, then you can see the differences between the current and the selected version of the content.
All well and good. However, an editor who has no idea about JSON, for example, can't really do anything with this view.
Is there a way (e.g. a plugin that I haven't found yet) to display the difference "visually"? So that you have, for example, 2 columns where the old and the new content is rendered next to each other instead of just displaying the code?
If I open a content and go to Info->Rollback and select a previous version, then you can see the differences between the current and the selected version of the content. All well and good. However, an editor who has no idea about JSON, for example, can't really do anything with this view. Is there a way (e.g. a plugin that I haven't found yet) to display the difference "visually"? So that you have, for example, 2 columns where the old and the new content is rendered next to each other instead of just displaying the code?
Hey, did you come up with something for this? We have the same issue and didn“t find a good option yet.
Best, Gerhard
Hey, no, unfortunately I haven't found a good solution yet either.
I will probably have to implement my own solution for this, but that is still a long way. First I have to set up Umbraco with everything we need.
