  • JMC 4 posts 74 karma points
    Jan 05, 2024 @ 20:25
    JMC
    INotificationAsyncHandler and BackgroundTaskQueue
    I am creating an implementation using MediaSavedNotification, in which I need to process the information of a CSV file, which has thousands of records and I am using this interface IBackgroundTaskQueue But I get the following notification Authorization error: Unauthorized access to URL: /umbraco/backoffice/umbracoapi/media/PostSave Contact your administrator for information. The whole process works correctly in the background service. When implementing the non-background processing, this works correctly, but the Media Library stays busy until it finishes processing the whole file. My code is below
    public class MediaSavedNotificationHandler(IBackgroundTaskQueue queue, IServiceProvider serviceProvider)
        : INotificationAsyncHandler<MediaSavedNotification>
        public async Task HandleAsync(MediaSavedNotification notification, CancellationToken cancellationToken)
            var mediaItems = notification.SavedEntities;
            foreach (var mediaItem in mediaItems)
                if (mediaItem.Key == MediaNodeIdIdentifiers.MaintenanceProvidersFileNodeId)
                    queue.QueueBackgroundWorkItem(async cancellationToken =>
                        using IServiceScope scope = serviceProvider.CreateScope();
                        var maintenanceProviderService = scope.ServiceProvider.GetRequiredService<IMaintenanceProviderService>();
                        await maintenanceProviderService.ImportProviders(mediaItem.Id);
                    notification.Messages.Add(new EventMessage("Maintenance Provider Notification",
                        "The Maintenance Providers import process has started and is running in the background.",
                        EventMessageType.Info));
                    return;
