I am developing a simple Umbraco extension and I want users to be able to change some settings via a custom dashboard.
I have created a dashboard using the Umbraco UI library controls (<uui-***>).
Now displaying the values is no problem, but I am stuck on binding them so that any changes are reflected back to the AngularJS controller (two way binding).
The ng-model directive does not work as it does on a simple <input> element.
Im not sure how I should go about this. Are there any good examples of mixing the UI library with AngularJS?
Sounds like a good idea to base new extensions for the current Umbraco-version on Lit to make the migration to Umbraco 14 easier.
As far as I know you probably have two options:
1.
Use component hand subscribe to events from the component to “manually” update you model.
If you component fire a “change” event you should be able to handle it with ng-change=“”.
2.
Build your own directives to provide the 2-way data binding (much like what the ng-model does). I think that this is probably overkill if you don’t use it in a lot of places.
Yes, it seemed like a good idea to check out the UI library before Umbraco 14 arrives.
I have tested a few things with ng- directives but it does not work all the time or with all lit components.
I ended up with this, which is what you suggested...
$scope.toggle = function (propName){
let currentValue = vm.settings[propName];
vm.settings[propName] = !currentValue;
I think this is more or less what you need to do. You could probably use a method to handle the event to avoid the angular.element(this)-part but as long at it works - it works =D
Two way binding with UI Library controls
Hello everyone,
<uui-***>).Now displaying the values is no problem, but I am stuck on binding them so that any changes are reflected back to the AngularJS controller (two way binding).
The
ng-modeldirective does not work as it does on a simple<input>element.Im not sure how I should go about this. Are there any good examples of mixing the UI library with AngularJS?
Hi!
1. Use component hand subscribe to events from the component to “manually” update you model.
2. Build your own directives to provide the 2-way data binding (much like what the ng-model does). I think that this is probably overkill if you don’t use it in a lot of places.
ng-directives but it does not work all the time or with all lit components. I ended up with this, which is what you suggested...And then calling the function....
Hi David!
Thanks for sharing!
angular.element(this)-part but as long at it works - it works =D// Markus
Hi David
Have you tried something like this?
where
vmrefer tothisin controller.The events in UI library need to be prefixed with
ng-on-in Angular, so:@click->ng-on-click@change->ng-on-changeetc.
Hi Bjarne,
I have now, since you mentioned it :)
Works like a charm, I will stick with it, it looks much better.
Thanks guys!
