Hi, I noticed that after upgrading a project from v10 to v13 the search results were a bit off.
After some testing with clean projects, starting from the UmBootstrap templates this same issue comes up.
V10 rich text editor preview:
V10 examine result:
V13 rich text editor preview:
v13 examine result:
As you can see in the v13 result the string 'v13_richText_SEARCH' is not in the result.
v13_richText_SEARCH
Can I enable the rich text editor to be indexed again in v13? Or do I need to write some custom code for this?
Thanks for any help.
Apparently this is caused by a bug https://github.com/umbraco/Umbraco-CMS/issues/15654
Rich Text Editors in Block Grid are not in Examine Index
V10 examine result:
v13 examine result:
v13_richText_SEARCH' is not in the result.Can I enable the rich text editor to be indexed again in v13? Or do I need to write some custom code for this?
