Greetings,
I have tried to follow the following instructions:
https://docs.umbraco.com/umbraco-cms/fundamentals/setup/server-setup/runtime-modes
As soon as I set "Development" or "Production" as the mode, I only get the error message:
Page not found. No template exists to render the document at URL '/'.
And in the console:
No physical template file was found for document type with alias website
What I have done so far. In appsettings.json I set the mode to Development and ModelsMode to "SourceCodeAuto".
I have removed the following settings from the .csproj:
<RazorCompileOnBuild>false</RazorCompileOnBuild> <RazorCompileOnPublish>false</RazorCompileOnPublish>
And the .csproj also contains "CopyRazorGenerateFilesToPublishDirectory", set to true.
I have published the website and also built it as a release build. But I still get the same errors. What am I doing wrong? Am I missing something?
My current appsettings.json file:
{ "$schema": "appsettings-schema.json", "Serilog": { "MinimumLevel": { "Default": "Information", "Override": { "Microsoft": "Warning", "Microsoft.Hosting.Lifetime": "Information", "System": "Warning" } } }, "Umbraco": { "CMS": { "ModelsBuilder": { "ModelsMode": "SourceCodeAuto", "FlagOutOfDateModels": true }, "Runtime": { "Mode": "Development" }, "Global": { "Id": "6accd714-46f7-4370-9c2b-a7d81a9087b6", "SanitizeTinyMce": true, "UseHttps": false }, "Content": { "AllowEditInvariantFromNonDefault": true, "ContentVersionCleanupPolicy": { "EnableCleanup": true } }, "Unattended": { "UpgradeUnattended": true }, "Security": { "AllowConcurrentLogins": false }, "WebRouting": { "UrlProviderMode": "Absolute" } } }, "ConnectionStrings": { "umbracoDbDSN": "Data Source=|DataDirectory|/Umbraco.sqlite.db;Cache=Shared;Foreign Keys=True;Pooling=True", "umbracoDbDSN_ProviderName": "Microsoft.Data.Sqlite" } }
Hello, I have the same issue. How did you fix this ?
I have the same exact problem. Installed the latest V13 and still. I can only run the site in Development mode.
V13: Production and Development mode - Page not found, physical template missing
Greetings,
And in the console:
