  • Peter 11 posts 81 karma points
    Feb 12, 2024 @ 20:38
    Peter
    Default values
    Is it possible to set "default values" in fields on an element-type? I have a base element-type, with a number of fields, and I inherit from this with several more specific element-types. On these more specific element-types, I'd like to have some of the field values "pre set" to values specific to their usage.
  • Danny Paul van Iersel 14 posts 122 karma points
    Feb 14, 2024 @ 15:54
    Hello Peter,
    Not sure if this is what you are looking for, but maybe it helps to point you in some direction.
    Example: https://github.com/dawoe/umbraco-journey-into-the-unknown/blob/master/App_Code/EditorModelEvents.cs
    Or a different example could be: https://docs.umbraco.com/umbraco-cms/reference/notifications/editormodel-notifications
    Kind regards, Danny Paul van Iersel
    Feb 14, 2024 @ 15:59
    Peter
    Thanks - I did start looking at the INotificationHandler pattern. I'll give it another shot. I am used to working in another cms called Sitecore, and here it is possible to set up "standard values" on its version of document-types. I thought Umbraco might have something similar built in.
