  • D1835 7 posts 77 karma points
    Feb 13, 2024 @ 10:18
    D1835
    'SiteBuilderBaseViewModel' does not contain a definition for 'CustomBlockList'
    I want to render the content of my blocklist on the nav of my website, however, I get this error:
    SiteBuilderBaseViewModel' does not contain a definition for 'CustomBlockList' and no accessible extension method 'CustomBlockList' accepting a first argument of type 'SiteBuilderBaseViewModel' could be found.
    @inherits UmbracoViewPage<SiteBuilderBaseViewModel>
    @using USNSiteBuilder.Core.Models
    @using USNSiteBuilder.Core.Interfaces
        Usnnavigation navigation = (Usnnavigation)Model.Navigation;
        if (navigation != null && navigation.CustomNav!= null && navigation.CustomNav.Any()) {
            int index = 1;
            foreach (var item in navigation.CustomNav) {
                <li><span><a href="#">item @($"{index}")</a></span></li>
                index++;
            @Html.GetBlockListHtml(Model.CustomBlockList)
    I have followed the docs and created the Components folder under blocklist. The file inside is "CustomBlockList.cshtml":
    @inherits Umbraco.Cms.Web.Common.Views.UmbracoViewPage<Umbraco.Cms.Core.Models.Blocks.BlockListItem>;
    @using ContentModels = Umbraco.Cms.Web.Common.PublishedModels;
        var content = (ContentModels.CustomBlockList)Model.Content;
    <h1>@content.PageName</h1>
    The final goal is to render what's inside the Block list and not the item @($"{index}"). Can anyone help?
  • Marc Love (uSkinned.net) 447 posts 1790 karma points
    Feb 13, 2024 @ 11:45
    I can see that you are using uSkinned Site Builder. Marc from uSkinned here.
    To access your custom block list you will need to use:
     @Html.GetBlockListHtml(Model.Value<BlockListModel>("customBlockList"))
    Marc
