Facing issue with Upgrade from Umbraco 8.0.1 to 8.18.13
We are facing an issue with upgrading from Umbraco 8.0.1 to 8.18.13
Once we update the package from Nuget, it shows the following error:
The database failed to upgrade. ERROR: The database configuration
failed with the following message: Invalid column name
'preventCleanup'. Please check log file for additional information
(can be found in '/App_Data/Logs/')
I have run the below query on SQL . No table have this column name
SELECT TABLE_NAME
FROM INFORMATION_SCHEMA.COLUMNS
WHERE COLUMN_NAME = 'preventCleanup';
Log Error
"System.Data.SqlClient.SqlException (0x80131904): Invalid column name 'preventCleanup'.\r\n at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)\r\n at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)\r\n at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)\r\n at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData()\r\n at System.Data.SqlClient.SqlDataReader.get_MetaData()\r\n at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption, Boolean shouldCacheForAlwaysEncrypted)\r\n at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest)\r\n at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)\r\n at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method)\r\n at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method)\r\n at Umbraco.Core.Persistence.FaultHandling.RetryPolicy.ExecuteAction[TResult](Func`1 func) in D:\\a\\1\\s\\src\\Umbraco.Core\\Persistence\\FaultHandling\\RetryPolicy.cs:line 172\r\n at NPoco.Database.ExecuteReaderHelper(DbCommand cmd)\r\n at NPoco.Database.ExecuteDataReader(DbCommand cmd)\r\n at NPoco.Database.<QueryImp>d__164`1.MoveNext()\r\nClientConnectionId:9e01f315-fd74-4731-b370-bee004cde492\r\nError Number:207,State:1,Class:16","InstanceId":"2a79313c","SourceContext":"Umbraco.Core.Persistence.UmbracoDatabase"
There are a bunch of breaking changes between v8.0.0 and v8.1.0, therefore I would recommend following the steps in the documentation and upgrade to 8.1.0 first, before trying to upgrade to 8.18.13
We tested that as well. Initially, when we upgraded to version 8.1, everything was working fine. However, after moving to the subsequent version, the same error began to occur.
We have two websites using the same version. We make the same changes to both sites as we did on the first website. However, only one site shows an error, while the other does not.
I'm not entirely sure if this is the correct way to resolve the issue.
Based on the error ("Invalid column name") and comparing it with my other upgraded site, I began by creating the missing column in the table.
After doing so, it started working.
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
GO
CREATE TABLE [dbo].[umbracoContentVersionCleanupPolicy](
[contentTypeId] [int] NOT NULL,
[preventCleanup] [bit] NOT NULL,
[keepAllVersionsNewerThanDays] [int] NULL,
[keepLatestVersionPerDayForDays] [int] NULL,
[updated] [datetime] NOT NULL
) ON [PRIMARY]
GO
ALTER TABLE [dbo].[umbracoContentVersionCleanupPolicy] WITH NOCHECK ADD CONSTRAINT [FK_umbracoContentVersionCleanupPolicy_cmsContentType_nodeId] CHECK (([contentTypeId]<>''))
GO
ALTER TABLE [dbo].[umbracoContentVersionCleanupPolicy] CHECK CONSTRAINT [FK_umbracoContentVersionCleanupPolicy_cmsContentType_nodeId]
GO
SELECT TABLE_NAME
ALTER TABLE [dbo].[umbracoContentVersion]
ADD preventCleanup bit NOT NULL DEFAULT 0;
SELECT TABLE_NAME
WHERE COLUMN_NAME = 'alias';
ALTER TABLE [cmsPropertyTypeGroup]
ADD [type] BIT NOT NULL DEFAULT 0;
ADD [alias] NVARCHAR(255) NULL;
SELECT TABLE_NAME
WHERE COLUMN_NAME = 'labelOnTop';
ALTER TABLE [dbo].[cmsPropertyType]
ADD
mandatoryMessage nvarchar(500) NULL,
validationRegExpMessage nvarchar(500) NULL;
ADD labelOnTop bit NOT NULL DEFAULT 0;
Log Error
Hi Sowndar,
https://docs.umbraco.com/umbraco-cms/fundamentals/setup/upgrading/version-specific#id-8.0.0-to-8.1.0
@owain Jones
Thank you for your reply.
Hi Sowndar,
Glad to hear that you got it working! 😄
Also, in case you're interested, I just had a look through Umbraco 8's database migrations; and I can see that the
preventCleanupcolumn was supposed to be added by the v8.18.0 migration: https://github.com/umbraco/Umbraco-CMS/blob/v8/dev/src/Umbraco.Core/Migrations/Upgrade/V818_0/AddContentVersionCleanupFeature.csStrange why it didn't work for you.
