Env: Azure App service, Blob storage and SQL database
It's been couple of years we are using this site hosted on the same infrastructure (Azure App service). This issue cropped up recently i would say after upgrading the V8.18.9.
Production web.config contains the recommended configuration as per the Doc:
Examine search internal and external stop working after every few days and we cannot rebuild the internal and external indexes from the back office, which cause the global search and site search to throw an error, it also effect other features like save and preview option.
Only way to bring back the site to the normal state is to remove all the files from App_data/TEMP/ExamineIndexes and restart the app service. Which work for another few days.
Here is full error:
Received an error from the server
An error occurred The 'ObjectContent`1' type failed to serialize the response body for content type 'application/json; charset=utf-8'.
Exception Details
System.InvalidOperationException: The 'ObjectContent`1' type failed to serialize the response body for content type 'application/json; charset=utf-8'.
Stacktrace
Inner Exception
System.ApplicationException: Could not create an index searcher with the supplied lucene directory
at Examine.LuceneEngine.Providers.LuceneSearcher.ValidateSearcher() in D:\a\1\s\src\Examine\LuceneEngine\Providers\LuceneSearcher.cs:line 215
at Examine.LuceneEngine.Providers.LuceneSearcher.GetLuceneSearcher() in D:\a\1\s\src\Examine\LuceneEngine\Providers\LuceneSearcher.cs:line 80
at Umbraco.Examine.ExamineExtensions.GetIndexDocumentCount(LuceneIndex indexer) in D:\a\1\s\src\Umbraco.Examine\ExamineExtensions.cs:line 181
at Umbraco.Examine.LuceneIndexDiagnostics.get_DocumentCount() in D:\a\1\s\src\Umbraco.Examine\LuceneIndexDiagnostics.cs:line 28
at Umbraco.Examine.UmbracoExamineIndex.get_DocumentCount() in D:\a\1\s\src\Umbraco.Examine\UmbracoExamineIndex.cs:line 197
at Umbraco.Web.Editors.ExamineManagementController.CreateModel(IIndex index) in D:\a\1\s\src\Umbraco.Web\Editors\ExamineManagementController.cs:line 179
at System.Linq.Enumerable.WhereSelectEnumerableIterator`2.MoveNext()
at System.Linq.Buffer`1..ctor(IEnumerable`1 source)
at System.Linq.OrderedEnumerable`1.<GetEnumerator>d__1.MoveNext()
at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.SerializeList(JsonWriter writer, IEnumerable values, JsonArrayContract contract, JsonProperty member, JsonContainerContract collectionContract, JsonProperty containerProperty) in /_/Src/Newtonsoft.Json/Serialization/JsonSerializerInternalWriter.cs:line 677
at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.SerializeValue(JsonWriter writer, Object value, JsonContract valueContract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerProperty) in /_/Src/Newtonsoft.Json/Serialization/JsonSerializerInternalWriter.cs:line 179
at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.Serialize(JsonWriter jsonWriter, Object value, Type objectType) in /_/Src/Newtonsoft.Json/Serialization/JsonSerializerInternalWriter.cs:line 95
at Newtonsoft.Json.JsonSerializer.SerializeInternal(JsonWriter jsonWriter, Object value, Type objectType) in /_/Src/Newtonsoft.Json/JsonSerializer.cs:line 1149
at System.Net.Http.Formatting.BaseJsonMediaTypeFormatter.WriteToStream(Type type, Object value, Stream writeStream, Encoding effectiveEncoding)
at System.Net.Http.Formatting.JsonMediaTypeFormatter.WriteToStream(Type type, Object value, Stream writeStream, Encoding effectiveEncoding)
at System.Net.Http.Formatting.BaseJsonMediaTypeFormatter.WriteToStream(Type type, Object value, Stream writeStream, HttpContent content)
at System.Net.Http.Formatting.BaseJsonMediaTypeFormatter.WriteToStreamAsync(Type type, Object value, Stream writeStream, HttpContent content, TransportContext transportContext, CancellationToken cancellationToken)
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at Umbraco.Web.WebApi.AngularJsonMediaTypeFormatter.<WriteToStreamAsync>d__1.MoveNext() in D:\a\1\s\src\Umbraco.Web\WebApi\AngularJsonMediaTypeFormatter.cs:line 52
at System.Web.Http.WebHost.HttpControllerHandler.<WriteBufferedResponseContentAsync>d__22.MoveNext()
Inner Exception
System.IO.FileNotFoundException: _4q.tvf
at Examine.LuceneEngine.Directories.SyncDirectory.OpenInput(String name) in D:\a\1\s\src\Examine\LuceneEngine\Directories\SyncDirectory.cs:line 252
at Lucene.Net.Store.Directory.OpenInput(String name, Int32 bufferSize) in d:\Lucene.Net\FullRepo\trunk\src\core\Store\Directory.cs:line 98
at Lucene.Net.Index.TermVectorsReader..ctor(Directory d, String segment, FieldInfos fieldInfos, Int32 readBufferSize, Int32 docStoreOffset, Int32 size) in d:\Lucene.Net\FullRepo\trunk\src\core\Index\TermVectorsReader.cs:line 83
at Lucene.Net.Index.SegmentReader.CoreReaders.OpenDocStores(SegmentInfo si) in d:\Lucene.Net\FullRepo\trunk\src\core\Index\SegmentReader.cs:line 367
at Lucene.Net.Index.SegmentReader.Get(Boolean readOnly, Directory dir, SegmentInfo si, Int32 readBufferSize, Boolean doOpenStores, Int32 termInfosIndexDivisor) in d:\Lucene.Net\FullRepo\trunk\src\core\Index\SegmentReader.cs:line 782
at Lucene.Net.Index.IndexWriter.ReaderPool.Get(SegmentInfo info, Boolean doOpenStores, Int32 readBufferSize, Int32 termsIndexDivisor) in d:\Lucene.Net\FullRepo\trunk\src\core\Index\IndexWriter.cs:line 689
at Lucene.Net.Index.IndexWriter.ReaderPool.GetReadOnlyClone(SegmentInfo info, Boolean doOpenStores, Int32 termInfosIndexDivisor) in d:\Lucene.Net\FullRepo\trunk\src\core\Index\IndexWriter.cs:line 630
at Lucene.Net.Index.DirectoryReader..ctor(IndexWriter writer, SegmentInfos infos, Int32 termInfosIndexDivisor) in d:\Lucene.Net\FullRepo\trunk\src\core\Index\DirectoryReader.cs:line 204
at Lucene.Net.Index.IndexWriter.GetReader(Int32 termInfosIndexDivisor) in d:\Lucene.Net\FullRepo\trunk\src\core\Index\IndexWriter.cs:line 392
at Lucene.Net.Index.IndexWriter.GetReader() in d:\Lucene.Net\FullRepo\trunk\src\core\Index\IndexWriter.cs:line 353
at Examine.LuceneEngine.Providers.LuceneSearcher.ValidateSearcher() in D:\a\1\s\src\Examine\LuceneEngine\Providers\LuceneSearcher.cs:line 204
Inner Exception
System.IO.FileNotFoundException: Could not find file 'C:\home\site\wwwroot\App_Data\TEMP\ExamineIndexes\Internal\_4q.tvf'.
at Examine.LuceneEngine.Directories.SyncIndexInput.SyncLocally(String fileName) in D:\a\1\s\src\Examine\LuceneEngine\Directories\SyncIndexInput.cs:line 182
at Examine.LuceneEngine.Directories.SyncIndexInput..ctor(SyncDirectory directory, String name, ILoggingService loggingService) in D:\a\1\s\src\Examine\LuceneEngine\Directories\SyncIndexInput.cs:line 98
at Examine.LuceneEngine.Directories.SyncDirectory.OpenInput(String name) in D:\a\1\s\src\Examine\LuceneEngine\Directories\SyncDirectory.cs:line 248
Seems like Examine no longer has the permission to regenerate the cache files. Only restarting the app service restore that permission and then from back office we can rebuild the indexes until it stop working again.
System.IO.FileNotFoundException: _c.fnm ---> System.IO.FileNotFoundException: Could not find file 'C:\home\site\wwwroot\App_Data\TEMP\ExamineIndexes\Internal\_c.fnm'.
File name: 'C:\home\site\wwwroot\App_Data\TEMP\ExamineIndexes\Internal\_c.fnm'
at Lucene.Net.Index.FieldInfos..ctor(Directory d, String name) in d:\Lucene.Net\FullRepo\trunk\src\core\Index\FieldInfos.cs:line 73
at Lucene.Net.Index.SegmentReader.CoreReaders..ctor(SegmentReader origInstance, Directory dir, SegmentInfo si, Int32 readBufferSize, Int32 termsIndexDivisor) in d:\Lucene.Net\FullRepo\trunk\src\core\Index\SegmentReader.cs:line 125
at Lucene.Net.Index.SegmentReader.Get(Boolean readOnly, Directory dir, SegmentInfo si, Int32 readBufferSize, Boolean doOpenStores, Int32 termInfosIndexDivisor) in d:\Lucene.Net\FullRepo\trunk\src\core\Index\SegmentReader.cs:line 779
at Lucene.Net.Index.IndexWriter.ReaderPool.Get(SegmentInfo info, Boolean doOpenStores) in d:\Lucene.Net\FullRepo\trunk\src\core\Index\IndexWriter.cs:line 656
at Lucene.Net.Index.DocumentsWriter.ApplyDeletes(SegmentInfos infos) in d:\Lucene.Net\FullRepo\trunk\src\core\Index\DocumentsWriter.cs:line 1265
at Lucene.Net.Index.IndexWriter.ApplyDeletes() in d:\Lucene.Net\FullRepo\trunk\src\core\Index\IndexWriter.cs:line 5367
at Lucene.Net.Index.IndexWriter.DoFlushInternal(Boolean flushDocStores, Boolean flushDeletes) in d:\Lucene.Net\FullRepo\trunk\src\core\Index\IndexWriter.cs:line 4374
at Lucene.Net.Index.IndexWriter.DoFlush(Boolean flushDocStores, Boolean flushDeletes) in d:\Lucene.Net\FullRepo\trunk\src\core\Index\IndexWriter.cs:line 4197
at Lucene.Net.Index.IndexWriter.PrepareCommit(IDictionary`2 commitUserData) in d:\Lucene.Net\FullRepo\trunk\src\core\Index\IndexWriter.cs:line 4034
at Lucene.Net.Index.IndexWriter.Commit(IDictionary`2 commitUserData) in d:\Lucene.Net\FullRepo\trunk\src\core\Index\IndexWriter.cs:line 4116
at Examine.LuceneEngine.Providers.LuceneIndex.IndexCommiter.TimerRelease() in D:\a\1\s\src\Examine\LuceneEngine\Providers\LuceneIndex.cs:line 1098
Really appreciate if you can point me in the right direction. Something has changed recently which effecting the Azure app services only.
Umbraco Version 8.18.13
Here is full error:
