  • Julius Goddard 41 posts 152 karma points
    Feb 26, 2024 @ 15:22
    Julius Goddard
    This site can’t provide a secure connection when trying to run Umbraco Project locally
    Hi All.
    I am trying to run an Umbraco v8 project locally and on starting the project in Visual Studio, I get the error: "This site can’t provide a secure connection".
    I have tried setting SSL Enabled to false in Project properties but that did not solve the problem.
    Is there any known way to solve this problem?
    Thanks.
    Feb 27, 2024 @ 07:56
    Julius Goddard
    Issue was resolved by using Firefox instead of Chrome.
    Even better solution: ticking the "Disable Cache" box in Chrome Developer Tools in the Network tab
  • ws-graham 10 posts 91 karma points
    Feb 27, 2024 @ 12:43
    ws-graham
    If you still wanted to use Chrome you can type "thisisunsafe" when you are on the page that shows "This site can’t provide a secure connection" and that bypasses the SSL errors and loads the page as normal.
    Feb 27, 2024 @ 12:58
    Julius Goddard
    Where do you type this in the window?
    Feb 27, 2024 @ 13:01
    ws-graham
    When you are on the page with the window active - I think this is the issue you are having - https://www.youtube.com/watch?v=RLom38ffPRo
    Feb 27, 2024 @ 13:47
    Julius Goddard
    Thanks but it didn't work.
