  • Kåre Mai 45 posts 283 karma points
    Mar 27, 2024 @ 10:42
    Kåre Mai
    ExternalIndex corrupted (wrong path)
    Our ExternalIndex is not working anymore and i get all sorts of errors in the log.
    System.IO.FileNotFoundException: Could not find file 'C:\Windows\TEMP\ExamineIndexes\db54d6a2928214e00581c19fa50a0ed6\ExternalIndex\_65.si'.
    File name: 'C:\Windows\TEMP\ExamineIndexes\db54d6a2928214e00581c19fa50a0ed6\ExternalIndex\_65.si'
    There is no folder under ExamineIndexes named "db54...".
    I have the following subfolders:
    \InternalIndex \MembersIndex \UmbracoFormsRecordsIndex
    If i go to the the ExternalIndex backend management it states:
    Could not find file 'C:\Windows\TEMP\ExamineIndexes\db54d6a2928214e00581c19fa50a0ed6\ExternalIndex\_65.si'. It may not be possible to rebuild the index. Please try deleting the entire ExternalIndex folder and then attempt to rebuild it again
    But i can't delete the requested folder as it does not exist!
    We're running Umbraco 13.1.0.
    Mar 27, 2024 @ 14:43
    Alex Skrypnyk
    Hi Kåre
    Did you try to rebuild all indexes? Does the solution have correct permissions to files and folders on the disk?
    Alex
    Mar 27, 2024 @ 14:45
    Kåre Mai
    Yes i can rebuild the other indexes just fine.
    Only the ExternalIndex gives this error with the wrong path. I don't know why it wants that db
    Apr 05, 2024 @ 08:44
    Kåre Mai
    I upgraded to Umbraco 13.2.2 and that have fixed the issue.
