  • Anzalna Nazar 8 posts 82 karma points
    Apr 05, 2024 @ 09:30
    Anzalna Nazar
    Page protection issue in Umbraco 13
    Hello everyone,
    I have recently created a project in Umbraco 13 and added some pages. I have also set the "Restrict Public Access" option with the Login and Error pages. enter image description here
    However, when I try to load the page, it gets redirected to the same page where the content gets replaced by the Login page content.
    To solve this, I need to add the redirect URL.
    Also, the 301 redirection is not working.
    Can anyone help me with this issue?
    Thank you.
    Apr 05, 2024 @ 12:34
    Huw Reddick
    That is correct, what are you trying to say is wrong exactly?
    Apr 08, 2024 @ 06:53
    Anzalna Nazar
    I have added redirection to the login page. So it should redirect to the login page.
    But here, when added redirection, the test page's inner content was replaced by the login page content. The URL is still the test page's URL.
    Like URL is of test page and its content is from login page
    Apr 08, 2024 @ 10:18
    Huw Reddick
    It's the default Umbraco behaviour.
    Apr 09, 2024 @ 04:30
    Anzalna Nazar
    Thanks!
    I have done it in versions 10 and 12, and it's working fine. (The page gets redirected to the login page). I found the above issue in version 13.
    Apr 09, 2024 @ 05:59
    Huw Reddick
    Are you certain you didn't do something different?
    I just fired up an old v10 site and the behaviour is exactly the same as you describe here. If I access a restricted page when not logged in I am redirected to the login page but the URL does not change.
  • Eranga Wijethunga 37 posts 178 karma points
    Oct 30, 2024 @ 21:22
    Eranga Wijethunga
    Have you found any solution for this ?
    Nov 04, 2024 @ 02:15
    Eranga Wijethunga
    This issue has sorted, Issue was not properly managed login method in Umbraco 13 it should be as follow using
    private readonly SignInManager<MemberIdentityUser> _signInManager;
    var signInResult = await _signInManager.PasswordSignInAsync(
                viewModel.Email,
                viewModel.Password,
                isPersistent: true,
                lockoutOnFailure: false
