  • Darren Hunter 146 posts 238 karma points
    Apr 17, 2024 @ 13:36
    Darren Hunter
    Pulling values from appsettings.json in Block List and Grid
    I have got an issue in Umbraco 13 I can't for the life of me work out how to pull some custom settings I have setup in the appsettings.json file for goodle maps in to a Block Grid or Block List.
    In the version 8 site we use.
    var apiKey = System.Configuration.ConfigurationManager.AppSettings["googleAPIKey"];
    But this dose not work in version 13.
    Can any one help. I dont want to have to write my own JSON parser if I dont have to,
  • Steve Morgan 1350 posts 4460 karma points c-trib
    Apr 17, 2024 @ 14:35
    Steve Morgan
    Example is for a view / partial but same idea for controller / view component.
    Inject the configuration - so for a view:
    @inject IConfiguration _configuration
    (possibly need @inject Microsoft.Extensions.Configuration.IConfiguration _configuration)
    Then you can access values in the Json like this:
    <h2>Debug: @_configuration["Umbraco:Cms:Hosting:Debug"]</h2>
    Or if it's not a string - you can use get value to use type setting:
    <h2>Debug: @_configuration.GetValue<bool>("Umbraco:Cms:Hosting:Debug")</h2>
    Apr 17, 2024 @ 14:56
    Darren Hunter
    Thanks you
    get the following code to work:
    @using Umbraco.Extensions @inherits Umbraco.Cms.Web.Common.Views.UmbracoViewPage
    @{ var maplat = Model.Content.Value("latitude").ToString(); var maplng = Model.Content.Value("longitude").ToString(); var apikey = _configuration["CustomSettings:googleAPIKey"];
    string s = "";
