Can we ReBuild Index in DeliveryApiContentIndex through PowerShell script?
I am using Umbraco 13 and I know we can manually run ReBuild Index in DeliveryApiContentIndex to get the latest changes using the Content Delivery API in back officer.
I want to do the same automatically through PowerShell, Can we do that? is that possible?
Is this required to build content delivery API index for the first time? Am not sure but the document says to build index.
If yes how we can do automatically instead of doing manually?
Hi, I am using Umbraco 13 and I know we can manually run ReBuild Index in DeliveryApiContentIndex to get the latest changes using the Content Delivery API in back officer. I want to do the same automatically through PowerShell, Can we do that? is that possible?
Index will be updated for each change , you don't need to rebuild it
HI, But we need to rebuild it when we enable Content Delivery API and run the Umbraco at initial.
Because I getting empty result when I enable Content Delivery API and try to consume content.
On first time - yes, but after it enambled it will updated progressively
Is this required to build content delivery API index for the first time? Am not sure but the document says to build index. If yes how we can do automatically instead of doing manually?
