I'm having an issue with the Multi URL Picker while trying to edit/remove an entry on mobile.
The edit/remove buttons aren't clickable.
if there is only one URL entry, it is still edit/remove able.
Might be a chromium issue, works in firefox mobile, but not chrome or android browser.
Hi there Zachary Allen
Just wanted to make sure. I know that you marked it with Umbraco 9.
is that correct? are you using Umbraco v9?
Multi URL Picker on mobile
