The only place that I think is relevant for this change is at appsettings-schema.json however, git ignores this file, so I'm not sure whether it would work when I pass the CI/CD processes and deploy in the cloud.
your umbraco site is not located in https://localhost:44334/umbraco that is where the backoffice (administration lives) and it is not possible to change that location.
So I understand I can't change it.
But is it possible to add any suffix? For example localhost:44334/umbraco/myproject ? and being redirected to the same page?
The project I'm dealing with is hosted on Azure.
I am building 2 umbraco projects: myproject, mysecondproject.
My customer wants one domain that would lead to both of the projects.
So they wrote a rule in azure:
If the site starts with /umbraco/myproject - I will be redirected to realdomain.com/umbraco/myproject
if the site starts with /umbraco/mysecondproject - I will be redirected to realdomain.com/umbraco/mysecondproject
I know it sounds silly, but they say that if they want to make a new domain it would cost them too many working hours and they want to check if it's possible to do so in Umbraco.
Thank you for your answer :)
I want the backoffice url to change to localhost:44334/umbraco/myproject.
So as far as I understand - it is impossible / not recommended?
Start umbraco on a different path than /umbraco
Hi all.
Currently, when I run my umbraco locally, it opens the browser with the website: https://localhost:44334/umbraco#/
I want that when I start the program, Umbraco will default start on page https://localhost:44334/myproject/ instead of the "umbraco#" path. If that's not possible, then https://localhost:44334/myproject/umbraco
How can I do it using Umbraco 13? Thanks!
It normally only opens at /umbraco if there is some kind of upgrade it thinks is required otherwise by default it should open your umbraco homepage.
Are you hosting your umbraco site as an application rather than as a standard root website?
If that is the case you should probably set the culture/hostname on your root node to be https://localhost:44334/myproject otherwise it expects it to be just https://localhost:44334/
If I understand your question correctly, my Umbraco site is not an application, it's a standard root website.
I want that my main umbraco will be located in https://localhost:44334/myproject instead of https://localhost:44334/umbraco
Is it even possible? Thanks in advance.
Sorry for being unclear.
So I understand I can't change it. But is it possible to add any suffix? For example localhost:44334/umbraco/myproject ? and being redirected to the same page?
For what reason?
The project I'm dealing with is hosted on Azure. I am building 2 umbraco projects: myproject, mysecondproject. My customer wants one domain that would lead to both of the projects. So they wrote a rule in azure: If the site starts with /umbraco/myproject - I will be redirected to realdomain.com/umbraco/myproject
You shouldn't use /umbraco that is a reserved path which points to the backoffice
Thank you for your answer :) I want the backoffice url to change to localhost:44334/umbraco/myproject. So as far as I understand - it is impossible / not recommended?
It is not possible
Thank you very much Huw :-)
