  • Arjan H. 226 posts 463 karma points c-trib
    May 23, 2024 @ 18:57
    Arjan H.
    uSync.Migrations: Umbraco.MediaPicker (legacy) not converted to Umbraco.MediaPicker3
    I've generated a Migration Pack in Umbraco 8.18.14 using uSync.Migrations. When running the conversion in Umbraco 10.8.6 the legacy media pickers (Umbraco.MediaPicker) are not being converted to Umbraco.MediaPicker3, even though this is a default migrator that comes with the package. Is there anything I need to do to enable this conversion?
  • Nijaz Hameed 38 posts 173 karma points
    May 23, 2024 @ 20:40
    Nijaz Hameed
    Hi Arjan, I think you can directly change the data type to Mediapicker3 and it won’t break anything. I did the same and nothing broken.
    May 23, 2024 @ 21:55
    Arjan H.
    Hi Nijaz! I was still under the impression that the MediaPicker3 was not downward compatible, but apparently that issue was fixed in 8.15:
    https://umbraco.com/blog/umbraco-815-release/
    Thanks for the tip!
