URGENT: mediacache not work properly after upgrade from 11.5.0 to 12.3.10
Hi, I have an urgent problem with media.
After upgrade a website from v11.5.0 to 12.3.10, not all media are showed in media folder (grid view)
Example:
Other media folder, instead, display correctly the images and other folders, display only some images (if I one the single image, I see the image correctly).
Other problem is that if I upload new files, the image is loaded correctly but mediacache not update and I don't see the new image in grid view.
This problem also affects the content because the images are not displayed even with the mediapicker
Example:
There is a way to force rebuild of mediacache?
I have this configuration:
Umbraco v12.3.10
SixLabors.ImageSharp v3.1.4
SixLabors.ImageSharp.Web v3.0.1 (if I try to update this to v3.1.2, GetCropUrl() does not work anymore and throw an exception)
Example:
Other problem is that if I upload new files, the image is loaded correctly but mediacache not update and I don't see the new image in grid view. This problem also affects the content because the images are not displayed even with the mediapicker
Example:
I have this configuration: Umbraco v12.3.10 SixLabors.ImageSharp v3.1.4 SixLabors.ImageSharp.Web v3.0.1 (if I try to update this to v3.1.2, GetCropUrl() does not work anymore and throw an exception)
Thank you Adriano
Hi to all, After many attempts, I finally found the solution this morning by performing the following steps:
I hope this post can help anyone who has encountered the same problem.
Have a nice day Adriano
