  • seanrock 262 posts 483 karma points
    Jun 19, 2024 @ 06:16
    seanrock
    corrupted member examine index
    umbraco v12.3.7 Azure webapp
    We've recently started having this issue where the member index gets corrupted and we cannot search in the member section. Really annoying and we cannot figure out whats causing it. Anyone else seeing this?
    eg:
    Lucene.Net.Index.CorruptIndexException: invalid deletion count: 2 vs docCount=1 (resource: BufferedChecksumIndexInput(MMapIndexInput(path="C:\home\site\wwwroot\umbraco\Data\TEMP\ExamineIndexes\ExternalIndex\segments_ge")))
    Jun 19, 2024 @ 06:31
    seanrock
    And we get this error in the backoffice in the browser console.
    umbraco-backoffice-js.js.v3820ba0df2426ec64b6d83605de8183ed4d59af6:147 Error: [ngRepeat:dupes] http://errors.angularjs.org/1.8.3/ngRepeat/dupes?p0=indexer%20in%20vm.indexerDetails&p1=string%3A%0D&p2=%0D at umbraco-backoffice-js.js.v3820ba0df2426ec64b6d83605de8183ed4d59af6:25:168 at umbraco-backoffice-js.js.v3820ba0df2426ec64b6d83605de8183ed4d59af6:349:428 at umbraco-backoffice-js.js.v3820ba0df2426ec64b6d83605de8183ed4d59af6:170:223 at m.$digest (umbraco-backoffice-js.js.v3820ba0df2426ec64b6d83605de8183ed4d59af6:171:351) at m.$apply (umbraco-backoffice-js.js.v3820ba0df2426ec64b6d83605de8183ed4d59af6:174:484) at k (umbraco-backoffice-js.js.v3820ba0df2426ec64b6d83605de8183ed4d59af6:125:445) at v (umbraco-backoffice-js.js.v3820ba0df2426ec64b6d83605de8183ed4d59af6:131:40) at y.onload (umbraco-backoffice-js.js.v3820ba0df2426ec64b6d83605de8183ed4d59af6:131:464)
    Jun 19, 2024 @ 06:46
    seanrock
    I've deleted all the index files, restarted the webapp (a few times), its rebuilt the index but still getting errors and cannot search in members.
    Jun 19, 2024 @ 07:57
    seanrock
    and its looking for the wrong index files.
    System.IO.FileNotFoundException: Could not find file 'C:\home\site\wwwroot\umbraco\Data\TEMP\ExamineIndexes\MembersIndex_1k.si'.
    _1k.si doesn't exist in the member index folder.
  • Simon Napper 116 posts 370 karma points
    Jun 19, 2024 @ 08:41
    Simon Napper
    Just looking at your first error, but that seems to indicate a problem with the ExternalIndex rather than the Member one, so I'm wondering if the problem is there and that in turn is stopping your Member index from building successfully?
    I'd probably try rebuilding the external index and if that's successful, then the member index and see if that generates member index files, are you getting any files at all for the member index? If you're still having problems then you could try deleting the index folder completely and restarting the web app as that should rebuild everything from scratch and should clear out any pesky corrupted files. Other things you could check for are disk space and if you have any custom code that's hooking into the indexing that might be causing an issue? Have you added an extra custom properties recently that could be causing an issue?
    Jun 19, 2024 @ 08:45
    seanrock
    Yes there are index files in the MembersIndex folder. I will try and delete all the indexes rather than just the members
    Jun 20, 2024 @ 07:24
    seanrock
    Yes I think there is/was an issue with the external index which was having a knock effect. Deleting all the examine indexes and restarting fixed the problem.
    Jun 20, 2024 @ 08:30
    Simon Napper
    Good to hear! If you can mark that as the answer, that would be great.
    Jun 20, 2024 @ 10:09
    seanrock
    Its actually a much bigger issue, https://github.com/umbraco/Umbraco-CMS/issues/16163
    Clearing the indexes is a quick fix but there is underlying issue as its reoccuring.
