  • Pankaj 11 posts 32 karma points
    Jun 19, 2024 @ 06:25
    Pankaj
    uSync is there have any code example how to import and export using c#
  • Simon Napper 116 posts 370 karma points
    Jun 19, 2024 @ 08:46
    Simon Napper
    You don't really need to use code to run uSync OOTB. When you've installed the package you should see an extra option in the settings section, that you can use set off the import/export process.
    There's more info about uSync here: https://our.umbraco.com/packages/developer-tools/usync/
    If not, can you tell us what it is that you're trying to do and what version of Umrbaco you're using?
  • Alex 3 posts 73 karma points
    Jun 19, 2024 @ 13:49
    Alex
    There's more info about uSync here: https://our.umbraco.com/packages/developer-tools/usync/ https://pinocasino.welcome-bonus.net/
    I have been using uSync to export and import data into Umbraco 8. Have there been any changes to Umbraco 9?
    Jun 19, 2024 @ 21:01
    Simon Napper
    If you're using the free version, not really I would say, it should feel very familiar to use.
