  • Ayo Adesina 445 posts 1059 karma points
    Jul 09, 2024 @ 12:31
    Ayo Adesina
    Issue with Required Toggle Property in 14.1.0-rc
    Hi Umbraco Team,
    I encountered an issue in version 14.1.0-rc related to a required toggle property in an existing document type.
    Here are the steps to reproduce the issue:
    Add a new toggle property to an existing document type and set it to "required." Attempt to publish a node of this document type.
    Expected Behavior:
    If the required toggle property is not set, the user should receive a clear error message indicating that the toggle property is required and why the node cannot be published. Actual Behavior:
    Umbraco saves the data in the document type but does not publish the node. A message is displayed stating that the node has been saved but not published, without providing a reason for the failure.
    To publish the node, I need to set the toggle to "true," publish the node, and then change it back to "false."
    At a minimum, Umbraco should inform the user that the reason for not being able to publish is due to the required toggle property being null, as it has never been set.
  • Huw Reddick 1932 posts 6722 karma points MVP 3x c-trib
    Jul 10, 2024 @ 09:08
    Huw Reddick
    If this is repeatable then you should report it as a bug on GitHub.
    I will say however that you probably need to set some custom validation too (value is not null), by default true/false fields generally work this way since null is also treated as being false by default.
