  • awm 187 posts 376 karma points
    Jul 22, 2024 @ 11:49
    awm
    Ideal project structure and dependencies
    I've been re-thinking how I structure my Umbraco projects and I came across this article: https://adolfi.dev/blog/umbraco-project-structure/
    In terms of dependencies, I'm slightly confused: I can understand wanting to separate out the Umbraco front-end from the Umbraco back-end logic but I don't understand how to set up refences in these scenarios.
    In the article above, if Web.UI holds the Umbraco installation and Web holds the Umbraco back-end logic, shouldn't Web reference Web.UI? How do I access the Umbraco assemblies from the Web project unless I basically do two full Umbraco installations in both projects?
  • Huw Reddick 1932 posts 6722 karma points MVP 3x c-trib
    Jul 23, 2024 @ 16:36
    Huw Reddick
    No, Web.UI is your website, it references Web which contains your business logic
    Jul 23, 2024 @ 17:17
    awm
    Thanks, Huw. I understand that, but as an example: If I'm writing custom controller logic in the Web project, how do I reference Umbraco if it's not added as a reference within the project?
    Wouldn't I need to reference the Umbraco assemblies within this project too, since Web.UI references Web and not the other way around?
    Sorry if this sounds like a daft question, but it's not making sense to me.
    Jul 23, 2024 @ 17:41
    Huw Reddick
    you would use one of the other umbraco assembly packages like Umbraco.Cms.Web.Common etc. where as your UI project will reference the main Umbraco.Cms package
    Jul 23, 2024 @ 17:46
    awm
    ahhh, that's what I'd thought. So the full Umbraco installation will be in Web.UI and only the required assemblies in Web?
