  • Yashwin2492 8 posts 28 karma points
    Aug 01, 2024 @ 16:16
    Yashwin2492
    Replacement for GetSingleByXPath()
    Trying to figure out the replacement for "IPublishedMediaCache.GetSingleByXPath()" in v14 since it became obsolete.
    I used this method since I don't want to make any DB calls to get the media using the file name.
  • girish 23 posts 116 karma points
    Aug 02, 2024 @ 07:05
    girish
    In Umbraco 14, the IPublishedMediaCache.GetSingleByXPath() method is obsolete, so you’ll need to use a different approach to get media by its filename without making direct database calls.
    Here’s how you can do it:
    Using IPublishedSnapshot and LINQ First, you’ll need to work with IPublishedContentQuery. This allows you to query published content, including media. If you’re looking for media items by their filename, LINQ is a good option.
    Inject IPublishedContentQuery: In your class, make sure to inject IPublishedContentQuery.
    private readonly IPublishedContentQuery _publishedContentQuery;
    public YourClass(IPublishedContentQuery publishedContentQuery)
        _publishedContentQuery = publishedContentQuery;
    Fetch Media by Filename: Use a LINQ query to filter media items by their filename.
    csharp
    Copy code
    public IPublishedContent GetMediaByFilename(string filename)
        // Get all media items
        var mediaItems = _publishedContentQuery.ContentAtRoot().DescendantsOrSelfOfType("media");
        // Filter by filename
        var mediaItem = mediaItems.FirstOrDefault(m => m.Name.Equals(filename, StringComparison.InvariantCultureIgnoreCase));
        return mediaItem;
    Using Examine for Better Performance If you have a large number of media items, using LINQ directly might not be very efficient. In this case, you can use Examine, Umbraco’s built-in search engine, for a faster solution.
    Inject IExamineManager:
    private readonly IExamineManager _examineManager;
    public YourClass(IExamineManager examineManager)
        _examineManager = examineManager;
    Fetch Media by Filename using Examine:
    csharp
    Copy code
        var searcher = _examineManager.SearchProviderCollection["ExternalIndexSearcher"];
        var query = searcher.CreateQuery("media")
                            .Field("nodeName", filename.MultipleCharacterWildcard())
                            .And().Field("__NodeTypeAlias", "media");
        var results = query.Execute();
        var firstResult = results.FirstOrDefault();
        if (firstResult != null)
            var mediaId = int.Parse(firstResult.Id);
            return _publishedContentQuery.Content(mediaId);
        return null;
    This way, you’re making use of Umbraco’s indexing capabilities to search for media by filename efficiently. This should help you avoid the performance issues you might encounter with direct LINQ queries on a large media library.
