  • Andreas Nylin 10 posts 80 karma points
    Aug 16, 2024 @ 09:25
    Andreas Nylin
    Problem with Custom TinyMCE editor and Smidge in production
    I have created a custom property editor with a TinyMCE editor.
    angular.module("umbraco")
        .controller("MyPluginController",
            function ($scope, $element) {
                    tinyMCE.init({
    Everything is working fine when i run the site in debug mode. But when I turn of debug the TinyMCE editor stops working. The reason is that the TinyMCE scripts for themes and plugins are now loaded from a different path.
    In debug mode they load from: /umbraco/lib/tinymce/themes/modern/theme.min.js
    But in release they load from: /sb/themes/modern/theme.js which results in 404 since it doesn't exists.
    If I understand things correctly it seems like Smidge is causing this. But I cannot understand how this works or why this happens. Or how I can stop Smidge from interfering.
    I've read that you can specify bundling options in the manifest file for the plugin but it doesn't seem to work for me.
    "propertyEditors": [
    "css": [],
    "javascript": [
    "~/App_Plugins/MyPlugin/myplugin.controller.js"
    "bundleOptions": "None"
    Anyone else experienced this problem?
  • Bishal Tim 26 posts 135 karma points c-trib
    Sep 03, 2024 @ 20:58
    Bishal Tim
    hey andreas,
    in production i would not suggest using "bundleOptions": "None" in my angular projects i used to show RTE like
      $scope.page.content = {
            label: '',
            description: '',
            view: 'rte',
            config: {
                editor: {
                    toolbar: ["ace", "undo", "redo", "cut", "copy", "styleselect", "fontselect", "fontsizeselect", "forecolor", "bold", "italic", "alignleft", "aligncenter", "alignright", "bullist", "numlist", "link", "umbmediapicker", "umbmacro", "table", "umbembeddialog"],
                    stylesheets: [],
                    style_formats: [{ title: "Heading 1", inline: "h1" }],
                    plugins: ["advlist", "autolink", "link", "code", "fullscreen", "textcolor", "colorpicker"],
                    dimensions: { height: 300, width: 800 }
            value: ""
    Nov 21, 2024 @ 10:44
    Andreas Nylin
    I'm still having problems with this. Is there some way to resolve script paths in a custom property editor?
  • Afreed 86 posts 383 karma points MVP
    Nov 21, 2024 @ 11:45
    Afreed
    Hi Andreas,
    Can you try loading the the tinyMceAssets like this
    function RteController($element, $scope, tinyMceAssets, assetsService, tinyMceService) {
              tinyMceAssets.forEach(function (tinyJsAsset) {
                  assetPromises.push(assetsService.loadJs(tinyJsAsset, $scope));
    or
    Manually adding the asset example like this one I did with ace
    angular.module("umbraco").controller("test", ["$scope", "assetsService", function ($scope, assetsService) {
      assetsService.loadCss("lib/ace-razor-mode/theme/razor_chrome.css");
    vm.aceOption = {
      mode: selectedType,
      theme: "chrome",
      showPrintMargin: false,
      advanced: {
        fontSize: '14px',
        enableSnippets: false,
        enableBasicAutocompletion: true,
        enableLiveAutocompletion: false
    I haven't tested this with TinyMce, hope it helps.
    Nov 29, 2024 @ 15:48
    Andreas Nylin
    Afreed, I think you are on to the correct solution. After some digging I ended up in the source code for the RTE propery-editor where assetservice also is used.
    Nov 29, 2024 @ 16:15
    Afreed
    I pulled the same from the repo as well. Glad that worked!
