But, when I try to search by letter category, 'A' returns ALL the authors, but 'B', 'C', 'D', etc all return the correct results. Is this a bug in my code?
public IEnumerable<ISearchResult> GetAuthorsFromLetterCategory(char letter, out long totalItemCount)
totalItemCount = 0;
if (_examineManager.TryGetIndex(AuthorsIndex.INDEX_NAME, out var index))
var results = index
.Searcher
.CreateQuery()
.Field("__IndexType", "author")
.And().Field("letterCategory", letter.ToString().Boost(10f))
.Execute();
totalItemCount = results.TotalItemCount;
if (results.Any())
return results;
return [];
I did find some suggestions online, but none has worked so far. Has anyone encountered this situation before?
Tried
options.Analyzer = new StandardAnalyzer(LuceneVersion.LUCENE_48, CharArraySet.EMPTY_SET);
options.Analyzer = new KeywordAnalyzer(); // made no difference either
I also tried creating a custom analyzer:
using Lucene.Net.Analysis;
using Lucene.Net.Analysis.Standard;
using Lucene.Net.Util;
namespace QuoteTab.Umbraco.Core.Analyzers
public class NoStopWordsAnalyzer : Analyzer
protected override TokenStreamComponents CreateComponents(string fieldName, TextReader reader)
// Use a standard tokenizer
Tokenizer tokenizer = new StandardTokenizer(LuceneVersion.LUCENE_48, reader);
// Directly pass the tokenizer without adding a stop word filter
TokenStream tokenStream = tokenizer;
return new TokenStreamComponents(tokenizer, tokenStream);
did register it with the custom index options:
if (!string.IsNullOrEmpty(name) && name.Equals(AuthorsIndex.INDEX_NAME))
options.Analyzer = new NoStopWordsAnalyzer();
options.FieldDefinitions = new FieldDefinitionCollection(
new FieldDefinition("slug", FieldDefinitionTypes.FullTextSortable),
new FieldDefinition("name", FieldDefinitionTypes.FullTextSortable),
new FieldDefinition("letterCategory", FieldDefinitionTypes.FullTextSortable),
new FieldDefinition("birthPlace", FieldDefinitionTypes.FullTextSortable),
new FieldDefinition("city", FieldDefinitionTypes.FullTextSortable),
new FieldDefinition("state", FieldDefinitionTypes.FullTextSortable),
new FieldDefinition("professionId", FieldDefinitionTypes.FullTextSortable),
new FieldDefinition("nationalityId", FieldDefinitionTypes.FullTextSortable),
new FieldDefinition("nationalityProfessionId", FieldDefinitionTypes.FullTextSortable)
options.UnlockIndex = true;
if (_settings.Value.LuceneDirectoryFactory == LuceneDirectoryFactory.SyncedTempFileSystemDirectoryFactory)
// if this directory factory is enabled then a snapshot deletion policy is required
options.IndexDeletionPolicy = new SnapshotDeletionPolicy(new KeepOnlyLastCommitDeletionPolicy());
var searcher = (BaseLuceneSearcher)index.Searcher;
var analyzer = new StandardAnalyzer(LuceneVersion.LUCENE_48, CharArraySet.EMPTY_SET);
var query = searcher.CreateQuery(null, BooleanOperation.And, analyzer, new Examine.Lucene.Search.LuceneSearchOptions() { });
I tried with new StandardAnalyzer(LuceneVersion.LUCENE_48, CharArraySet.EMPTY_SET); and also tried like this:
totalItemCount = 0;
var searchTerm = letter.ToString();
var analyzer = new NoStopWordsAnalyzer();
.And().Field("letterCategory", searchTerm)
.Execute();
totalItemCount = query.TotalItemCount;
if (query.Any())
return query;
return [];
The results are retuing 0 now, instead of all of them, so at least something changed!
Is it possible that I'm setting up my index options incorrectly?
I have made several attempts, using different approaches, and it's always the same, it works for other letters (B,C,D...) but not for A.
for now I'm stuck :(
Even tried this (just for reference, not actual solution)
List<LetterCategorySearchResult> results = new();
using (var directory = FSDirectory.Open(new DirectoryInfo("umbraco\\Data\\TEMP\\ExamineIndexes\\AuthorsIndex")))
using (var analyzer = new NoStopWordsAnalyzer()) // Use your custom analyzer here
// Create a query parser
var queryParser = new QueryParser(LuceneVersion.LUCENE_48, "letterCategory", analyzer);
// Parse the query
Query query = queryParser.Parse(letter.ToString());
// Set up the searcher
using (var reader = DirectoryReader.Open(directory))
var searcher = new IndexSearcher(reader);
// Execute the search
TopDocs topDocs = searcher.Search(query, 9999999);
foreach (ScoreDoc scoreDoc in topDocs.ScoreDocs)
Document doc = searcher.Doc(scoreDoc.Doc);
LetterCategorySearchResult searchResult = new(doc, scoreDoc.Score);
results.Add(searchResult);
return results;
It also doesn't seem to matter the type of Analyzer I configure with the index, Umbraco always displays it as StandardAnalyzer. Does that mean the backoffice has a bug and it doesn't show the correct analyzer, OR Umbraco has a bug and it doesn't take the custom analyzer?
And also like this (with no success)
options.Analyzer = new StandardAnalyzer(LuceneVersion.LUCENE_48, new CharArraySet(LuceneVersion.LUCENE_48, 0, true));
And the search
totalItemCount = 0;
//https://our.umbraco.com/forum/using-umbraco-and-getting-started/114576-examine-index-search-returns-all-results-for-lettercategory-a
var analyzer = new StandardAnalyzer(LuceneVersion.LUCENE_48, new CharArraySet(LuceneVersion.LUCENE_48, 0, true));
var searcher = index.Searcher as LuceneSearcher;
var query = searcher!
.CreateQuery(null, BooleanOperation.Or, analyzer, new Examine.Lucene.Search.LuceneSearchOptions())
.Execute();
if (query.Any())
return query;
return [];
Examine Index Search returns all results for letterCategory == 'A'
Hi there,
I have created an author Index with the following fields
HELP!! :-(
I belive that "A" is stop word and removed from query, you can change analyzer or change stopwords dictionary
Thank you Yakov Lebski,
Tried
and configured the custom options in a composer
Nothing is working so far, and the BackOffice is showing StandardAnalyzer instead of the NoStopWordsAnalyzer I just created.
Any documentation I could look into? I have no idea what is wrong :(
can you try
I tried with
new StandardAnalyzer(LuceneVersion.LUCENE_48, CharArraySet.EMPTY_SET);and also tried like this:The results are retuing 0 now, instead of all of them, so at least something changed!
And the search
Ended up using this FUGLY hack.... just in case anyone needs it, or finds a solution
